Re: Hole Pattern for Parachute Enclosure
[Re: jughed]
#2675712
07/08/19 08:24 PM
07/08/19 08:24 PM
Posts: 11,558 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Depends on the size of the pack which depends on the size of the chute, if you're using the 4 corner fasteners. We just use a small flange in the center for a conventional chute. Doesn't take much to hold the chute pack.
[Re: CMcAllister]
#2675743
07/08/19 09:17 PM
07/08/19 09:17 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
As stated there is no "standard" answer for that question. Most of the plates you see are around 6x6 but doesn't mean anything. Every chute I have bought and used had no holes for mounting at all. You cut the bag for screws.
