Thumping Noise While Turning Left #267492
03/26/09 07:30 PM
03/26/09 07:30 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
I was driving my car in the rain today and noticed that sometimes when I turned left, there was a thump sound kind of like a dent popping but a lower pitch. There are no differences in handling when it happens only the sound. The car tracks nice and straight. Any Ideas?
Re: Thumping Noise While Turning Left [Re: bordin34] #267493
03/26/09 07:35 PM
03/26/09 07:35 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
wheel bearing?
Re: Thumping Noise While Turning Left [Re: bordin34] #267494
03/26/09 07:35 PM
03/26/09 07:35 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
windshield wipers?
Re: Thumping Noise While Turning Left [Re: rabid scott] #267495
03/26/09 07:38 PM
03/26/09 07:38 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Rythmic? Relative to speed. Can it be done in a parking lot. Is it possible to make 3 rights to eliminate the problem?
Re: Thumping Noise While Turning Left [Re: DennisH ] #267496
03/26/09 07:45 PM
03/26/09 07:45 PM
must be all the smog out there on the left coast
Re: Thumping Noise While Turning Left [Re: RapidRobert] #267497
03/26/09 07:48 PM
03/26/09 07:48 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
The wheel bearings are new, wipers were off, and the tires and wheels aren't new.
Re: Thumping Noise While Turning Left [Re: bordin34] #267498
03/26/09 07:57 PM
03/26/09 07:57 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Ball joint?
I want my fair share
Re: Thumping Noise While Turning Left [Re: bordin34] #267499
03/26/09 08:02 PM
03/26/09 08:02 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Sure-grip chatter?
Re: Thumping Noise While Turning Left [Re: DoctorDiff] #267500
03/26/09 08:06 PM
03/26/09 08:06 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
It's an open rear a ball joint sounds possible, but wouldn't I feel it in the wheel?
Re: Thumping Noise While Turning Left [Re: bordin34] #267501
03/26/09 09:57 PM
03/26/09 09:57 PM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
First I would check my upper control arms, make sure nothing loose and take a look at control arm bushings.
Re: Thumping Noise While Turning Left [Re: 268RTs4ME] #267502
03/26/09 11:05 PM
03/26/09 11:05 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Sounds like a dead critter to me !!!
Re: Thumping Noise While Turning Left [Re: Stanton] #267503
03/27/09 12:04 AM
03/27/09 12:04 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
New wheel bearings adjusted correctly? They will go up in smoke very quickly if not.
Wheel weights on the backside of the wheel hitting when the wheel is turned?
Re: Thumping Noise While Turning Left [Re: Neil] #267504
03/27/09 12:08 AM
03/27/09 12:08 AM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
I had a similar noise in an 77 Dodge dually. It wound up being worn-out sway bar bushings.
Re: Thumping Noise While Turning Left [Re: bordin34] #267505
03/27/09 01:35 AM
03/27/09 01:35 AM
AndyF Offline
AndyF  Offline
Could be a bad tire. My car did that when a belt broke inside the tire. Could only hear it at low speeds turning one direction.
Re: Thumping Noise While Turning Left [Re: AndyF] #267506
03/27/09 06:54 AM
03/27/09 06:54 AM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
PM 71autoxr (Rick) -- he just had a similar problem with his Challenger -- he fixed it this past weekend, but I can't recall what he said it was.
Re: Thumping Noise While Turning Left [Re: Hotwheelsjr] #267507
03/27/09 08:35 AM
03/27/09 08:35 AM
NY usa
540challenger Offline
NY usa
LoL well way too tease the guy. J/K
My friends challenger did that at a closer in spection i notice that his upper control arms bolt were loose.
Re: Thumping Noise While Turning Left [Re: bordin34] #267508
03/27/09 11:07 AM
03/27/09 11:07 AM
N. Arkansas
STREETSHAKER Offline
N. Arkansas
I had a wheel weight barely scraping something only in turns.
Re: Thumping Noise While Turning Left [Re: STREETSHAKER] #267509
03/27/09 11:13 AM
03/27/09 11:13 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
This is going to sound weird but I had a similar
thing on my Dart only turning one way. It ended
up being the one muffler moving enough to hit
the square part of my driveshaft where it bolts
up to the U joints. Scratched my head over that
one for a long time.
Re: Thumping Noise While Turning Left [Re: Hotwheelsjr] #267510
03/27/09 12:59 PM
03/27/09 12:59 PM
NE Ohio
71 FJ6 Charger Offline
NE Ohio
And he's a moderator,makes it funnier!
'71 383HP FJ6 Charger SE
Re: Thumping Noise While Turning Left [Re: bordin34] #267511
03/27/09 01:01 PM
03/27/09 01:01 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I had a wheel weight do that. I had just got new tires and I thought they screwed something up everytime I took a hard left I'd hear thum thump thump... I got home jacked up the car and when I laid the wheel on the ground face down I could see where the wheel weight was hitting. I beat on it to flatten it and it was fine after that.
