Would an 09 Aspen 5.7 hybrid be an Eagle?
#2675058
07/07/19 12:06 AM
07/07/19 12:06 AM
Posts: 2,255 IL
furious70
IL
Or are those 5.7's equipped with older heads and other parts?
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: Would an 09 Aspen 5.7 hybrid be an Eagle?
[Re: furious70]
#2675083
07/07/19 06:28 AM
07/07/19 06:28 AM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
Yes, look at the top of the block , under the Throttle Body you should see a solenoid that will be the VVT activation solenoid
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: Ray408G3Hemi]
#2675782
07/08/19 11:02 PM
07/08/19 11:02 PM
Posts: 2,255 IL
furious70
IL
is that the plug at the left base of the TB?
[Re: furious70]
#2675786
07/08/19 11:20 PM
07/08/19 11:20 PM
Posts: 2,255 IL
furious70
IL
also does the front cover look broke off on the lower right?
[Re: furious70]
#2676086
07/09/19 08:19 PM
07/09/19 08:19 PM
Ray408G3Hemi
Springtown Pa
Cover looks fine , it's an 09 and up, look under the TB for the VVT activation solenoid
