Boosting stock radios #2674536
07/05/19 06:03 PM
07/05/19 06:03 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Anyone ever put an amp on there stock radios? Wondering what's out there and how does it sound...…..Thaxs. wave
Re: Boosting stock radios [Re: racerx] #2674685
07/06/19 07:07 AM
07/06/19 07:07 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Not as good as an aftermarket with pre-outs before the internal amp. Otherwise you will have to buy a lineout convertor like Scosche offers to run it. This is an amp and sub and you can see the line out adaptor tucked in behind it. In this case I have the line in soldered directly to the rear speakers. Better than factory but not as good as a high end unit but this was a free upgrade for me.
Re: Boosting stock radios [Re: redraptor] #2674722
07/06/19 10:01 AM
07/06/19 10:01 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxs ….for that reply, I have seen those sub/amps for sell .But never have herd one. When dodge first came out with 1st gen rams they had the system call the infinity nice sounding system up how would you compare this setup to it(if you have herd the infinity sound system?)What i'm trying to do is get better sound with out altering the looks of the stock dash.
Re: Boosting stock radios [Re: racerx] #2675090
07/07/19 07:19 AM
07/07/19 07:19 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
My 2000 Dakota had that. Good sound quality although eventually both speakers dry rotted. My basslink would equal or better that for thump. I would suggest upraded speakers if yours are stock for mid and upper range.
Re: Boosting stock radios [Re: redraptor] #2675122
07/07/19 10:29 AM
07/07/19 10:29 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
so did they come with a special type speaker or the standard one , I up graded the two door speakers to some pioneers and left the rear stock.
Re: Boosting stock radios [Re: racerx] #2675129
07/07/19 10:49 AM
07/07/19 10:49 AM
md
mopars4ever Offline
mopars4ever  Offline
md
https://www.allpar.com/stereo/speaker-repair.html
The infinity speakers that were in my car years ago had small amps on the speakers.
Re: Boosting stock radios [Re: racerx] #2679313
07/20/19 07:11 AM
07/20/19 07:11 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
The door speakers on my Dak were Infinity. They looked special as they had HUGE magnets on them. The ones I replaced them with, not so much. frowwn
Re: Boosting stock radios [Re: redraptor] #2679429
07/20/19 01:30 PM
07/20/19 01:30 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxs…...the speakers that I installed were some pioneers that I got out of the salvage yard. They fit nice ,but sound no better than the factory ones. work wondering what the new dodge truck has? I'll like to keep the factory stock look with much better sound.
Re: Boosting stock radios [Re: racerx] #2679478
07/20/19 04:19 PM
07/20/19 04:19 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
What is the vehicle? How the speakers are mounted can be even more critical to good sound than the brand of speaker. To get decent low end speakers need to be enclosed on the back side.
Re: Boosting stock radios [Re: MarkZ] #2679976
07/22/19 05:44 AM
07/22/19 05:44 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
95 Dodge ram 1500 up stock radio, stock speaker location. trying to keep it as (stock looking as possible). but the same sound quality as the infinity systems that came out in the first gen rams.
