Coilovers tubular k frames #2674285
07/05/19 12:59 AM
07/05/19 12:59 AM
Canada
Cape Offline OP
Cape  Offline OP
Canada
I was considering bobs pro fab but I don’t think he’s in business anymore. So my question is who would you go with if you were going to get rid of the torsion bar suspension and go Coilovers? Who makes the best kits? What’s the pros and cons to going Coilovers or just keeping the torsion bars.
My car is a street/strip 69 charger mostly geared for the strip though. I will drive it around but that’s it. It’s a 478 Hemi 827hp @7700 G101a transmission twin 8.5 racing clutch browel bell housing Dana 60 with 4.88 in it. I haven’t had it to the track yet I’m just putting it all back together now. Just wondering the people’s opinions on front suspend stuff. Right now I have the stock k frame with QA1 upper and lower control arms and strange disc brakes on the front and rear. If I forgot anything let me know. Thanks
Re: Coilovers tubular k frames [Re: Cape] #2674288
07/05/19 01:24 AM
07/05/19 01:24 AM
Cab_Burge Online work
Cab_Burge  Online Work
I bought a Rieleys (sp?) tubular K member that has coil overs, front mounted rack and pinion steering which eliminates the need for torsion bars for a customers 1971 Challenger with a 572 C.I. pump gas street Hemi street and local car show car. He is very happy on how it looks and I had Forest Finscher install it while he was setting up the rear end and widening the rear wheel wells and so on, Forrest says likes using those kits up
Re: Coilovers tubular k frames [Re: Cab_Burge] #2674309
07/05/19 06:48 AM
07/05/19 06:48 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Im running a HDK - beautiful parts, well thought out and working really well on my street/strip Hemi A body.
Service from Denny was awesome.....and I'm on the other side of the pond. up
IMHO, you can't go wrong with this setup, Denny will look after you.
http://www.moparsuspension.com/mopar-suspension-kits/mopar-suspension-products.php
Re: Coilovers tubular k frames [Re: Cape] #2674316
07/05/19 08:04 AM
07/05/19 08:04 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I have the Bob's Profab front suspension on my e-body nice setup up and I tell changing the oil pan is a breeze, not have to drop that drag link. His set up runs straight and true down the 1320.
Re: Coilovers tubular k frames [Re: Cape] #2674317
07/05/19 08:10 AM
07/05/19 08:10 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
best and most proven on the market today is the https://www.reillymotorsports.com/ easy install, top quality all the way around, second to none customer service.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Coilovers tubular k frames [Re: abodyjoe] #2674323
07/05/19 08:51 AM
07/05/19 08:51 AM
NY usa
540challenger Offline
NY usa
That's the brand I am running, 8 years no issue s.
Re: Coilovers tubular k frames [Re: 540challenger] #2674341
07/05/19 09:25 AM
07/05/19 09:25 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I bought an Alterkation for the Valiant , its a good product .. I will say these two things .
Why, after all of the K-Frames he has sold , can't he get the square tubing mandrel bent is beyond me and, he is not the greatest help before or after sale .
On my 67 I bought one from Carl Gerst
http://gerstsuspensions.com/products/
It is made very nice, looks very nice, fits , works very nice .. Carl will take your call almost any hour or the day, very helpful, it arrived before he promised it
and, it cost less than the ALTERKATION
I almost bought one from HDK too. , he was helpful and his product is nice
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Coilovers tubular k frames [Re: bigdad] #2674374
07/05/19 10:58 AM
07/05/19 10:58 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
+1 for GERST. It was ~$800 less than RMS when I priced them out. Install was easy. Very nice product!
[Linked Image]IMG_2719 by Greg Ault, on Flickr
Re: Coilovers tubular k frames [Re: gsmopar] #2674391
07/05/19 11:31 AM
07/05/19 11:31 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have two Magnum Force kits on my current cars, and no issues with either.....
Re: Coilovers tubular k frames [Re: abodyjoe] #2674448
07/05/19 02:00 PM
07/05/19 02:00 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I couldn't even get a call back or response to my email inquiry when I was looking at these set ups. Ended up going with Gerst. He has been great to work with.
Ok
Re: Coilovers tubular k frames [Re: cudatom] #2674579
07/05/19 07:52 PM
07/05/19 07:52 PM
Superfreak
Superfreak
I went with RMS and I upgraded the small U brackets. The customer service was excellent before and especially after and he was great to talk with and I am in Kanaka.
Re: Coilovers tubular k frames [Re: ] #2674642
07/05/19 10:51 PM
07/05/19 10:51 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I went with Reilly........early A body , the track is wider than stock and I had a problem with the tire getting into the passenger side wheel well lip on the front edge.
Probably would not be an issue with stock dia, wheel and tire combo.
But the ride is great , and since I had to build headers for the deal , I think it was a great choice.
I spoke with Bill several times and even after purchase issues were a simple phone call from solved.
Re: Coilovers tubular k frames [Re: cudatom] #2674667
07/06/19 01:03 AM
07/06/19 01:03 AM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Thanks for all the input. Seems like the story’s I’ve heard of tut frame bending from not having torsion bars is just not true. I do have frame connectors as well. I really was interested in people’s experiences with these kits and are they that much better then torsion bar suspension and by the sounds of it if you can afford it it’s the way to go. Thanks again
Re: Coilovers tubular k frames [Re: Cape] #2674743
07/06/19 10:32 AM
07/06/19 10:32 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
While mine wouldn’t fit your criteria (race only, a bit on the dainty side)... the reasons you’re going this route you will appreciate. Car handles so nice! Great shocks available, room for any oil pan under the sun. Take it up another notch with custom headers to take advantage of all that “free” room. I like “easy” and working on the car with this set up definitely helps in that department.
Re: Coilovers tubular k frames [Re: cudatom] #2674841
07/06/19 01:19 PM
07/06/19 01:19 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Which kit is that your using?
Re: Coilovers tubular k frames [Re: Cape] #2674902
07/06/19 04:59 PM
07/06/19 04:59 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Mine was built at Comp Chassis in Phoenix.... this pict was actually taken in April about a week before MaTS. I pretzeled it in a wheel stand along with bending the car. It has another new K in it now..... and wheelie bars that I should have had to begin with. W8 small block.... who knew! laugh2
Re: Coilovers tubular k frames [Re: Cape] #2674904
07/06/19 05:00 PM
07/06/19 05:00 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Tory Shellhamer also makes a front K set up in different forms. You can find his on Facebook
Re: Coilovers tubular k frames [Re: J_BODY] #2675371
07/07/19 10:12 PM
07/07/19 10:12 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
Alterkation for me, great services.
suspension
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Coilovers tubular k frames [Re: caper] #2675557
07/08/19 01:41 PM
07/08/19 01:41 PM
Missouri
galen Offline
galen  Offline
Missouri
I ran a RMS on the 65. Putting a Gerst in my 68 pictured. It is a very nice piece with a lot of adjustability. I purchased it with an extra K member. One with RB mounts, one with Gen 2 hemi mounts.
Re: Coilovers tubular k frames [Re: galen] #2676590
07/11/19 03:17 PM
07/11/19 03:17 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I am using an HDK from Denny. I love it! Easy to put. Straight as an arrow at speed!
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
