Originally Posted by Cape
Thanks for all the input. Seems like the story’s I’ve heard of tut frame bending from not having torsion bars is just not true. I do have frame connectors as well. I really was interested in people’s experiences with these kits and are they that much better then torsion bar suspension and by the sounds of it if you can afford it it’s the way to go. Thanks again
IMO, these are the 2,5 improvements you can expect:
1. Improved header clearance
2. Improved oil pan fitment
2,5 Lighter weight when going from drums to discs.
Any handling improvements will be because of lighter weight and correcting your alignment from a previous poor setting.
These coil over replacement tube members offer nearly nothing handling wise over a proper TB set-up.
