bore clearance arias forged 340 pistons #2674145
07/04/19 05:18 PM
07/04/19 05:18 PM
Atlanta, GA
mgoblue9798 Offline OP
Atlanta, GA
Bought a set of new old stock 340 forged arias pistons. Paper says .003 piston clearance spec. Does this mean .a.006 bigger bore than the piston size?
This seems a little tight. IIRC the old trw forged pistons used to call for about .006 clearance if I remember correctly.
Re: bore clearance arias forged 340 pistons [Re: mgoblue9798] #2674149
07/04/19 05:41 PM
07/04/19 05:41 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
clearance is in the piston, not the bore.
Re: bore clearance arias forged 340 pistons [Re: lewtot184] #2674154
07/04/19 05:48 PM
07/04/19 05:48 PM
Washington
madscientist Offline
Washington
Exactly. The bore size is nominal, the piston size is the clearance. Measure the skirt and that will tell you how much clearance you need. Add .0005-.0010 if you think you are going to abuse the engine.
Re: bore clearance arias forged 340 pistons [Re: lewtot184] #2674155
07/04/19 05:48 PM
07/04/19 05:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Presumably the Arias forging has better control of its expansion than the old TRW clankerweights?
Worth a call to their tech line.
