Education on small blocks #2674032
07/04/19 01:56 PM
07/04/19 01:56 PM
USA
hudsonhornet7x Offline OP
USA
With all the reading here about when, not if, your stock big block will crack the mains, cylinder walls, etc, I would like to know opinions about small block Chrysler engines. I have never had the opportunity to work with them. so here goes:
What is the best stock block to look for and how much can you safely make without worrying about hurting the block?
Are any aftermarket blocks available?
How big can you safely make a stock small block in cubic inches?
What are some good books to learn about small block Chryslers?
Thank you all, I am sure I left out some information.
Re: Education on small blocks [Re: hudsonhornet7x] #2674086
07/04/19 03:20 PM
07/04/19 03:20 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I know very very little about small blocks because I'm mostly a Hemi guy. But I do know this: If I was going to ever run a small block, it would be a NASCAR engine. Those things are pretty cheap, readily available, and they definitely have got some snort!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Education on small blocks [Re: Hemi_Joel] #2674138
07/04/19 05:02 PM
07/04/19 05:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In a LA stock block you can make 600hp no problem
wave
Re: Education on small blocks [Re: hudsonhornet7x] #2674153
07/04/19 05:48 PM
07/04/19 05:48 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I think Ritter is the only game for new race blocks. There are still a few X or R3 blocks that pop up from time to time. Expect to pay $4k or so for an unused one?
A 4.125" crank will get you better than 426 ci.
There is a ton of free info if you are willing to google it online, but the Larry Shepard books are pretty well regarded.
Re: Education on small blocks [Re: gzig5] #2674268
07/04/19 10:57 PM
07/04/19 10:57 PM
USA
USA
Thank you guys, I think a big inch small block would be a blast. I have read about the Ritter blocks and problems. Do you think the problems are behind them?
Re: Education on small blocks [Re: hudsonhornet7x] #2674274
07/04/19 11:47 PM
07/04/19 11:47 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
How fast are you looking to go and at what weight? A stock Small block will hold up to quite a bit.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Education on small blocks [Re: pittsburghracer] #2675416
07/08/19 01:50 AM
07/08/19 01:50 AM
dogdays Offline
dogdays  Offline
Skip right over to the Hemi. You know you want to. If you're going to buy all LA stuff just don't. Start oiut with the new Hemi and even though it costs more it weighs less and has a much higher hp potential.
R.
Re: Education on small blocks [Re: hudsonhornet7x] #2675453
07/08/19 09:54 AM
07/08/19 09:54 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
While I don't have one, it sounds like the Ritter blocks are ready for prime time.
However if I did get one, I would make sure it was a "latest version" and I would have a top notch machine shop check if fully before using it.
