440 Blocks - More Polls #2673591
07/03/19 01:29 PM
07/03/19 01:29 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
More polls to collect the info about when you have cracked a 440 block.
Stroke
multiple choice
Votes accepted starting: 07/03/19 01:25 PM
Port Size
multiple choice
Total Timing
multiple choice
# of passes before cracked
multiple choice
Votes accepted starting: 07/03/19 01:28 PM
Re: 440 Blocks - More Polls [Re: DusterKid] #2673597
07/03/19 01:51 PM
07/03/19 01:51 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Color of engine———black
Color of car——-//Black
Color of hair driver had———— Gray with balding areas.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 440 Blocks - More Polls [Re: pittsburghracer] #2673610
07/03/19 02:22 PM
07/03/19 02:22 PM
Washington
madscientist Offline
Washington
The number of passes before cracking at best is a guess. Most guys don't look at their stuff often enough to know when the fracture occurred. They either catch it when it's ready to blow, or after the bones are out.
Who knows, it may have cracked in 10 runs, or 30 but you don't find it until 150.
Re: 440 Blocks - More Polls [Re: madscientist] #2673637
07/03/19 03:04 PM
07/03/19 03:04 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The biggest cause of cracking blocks I have encountered is usually a combination of heavy bob weight and excessive detonation - the detonation is usually due to the tuner either getting aggressive or just being stupid!
Then there is those rare occasions when they just plain break due to fatigue with no explanation... Go figure!
Re: 440 Blocks - More Polls [Re: DoubleD] #2673891
07/04/19 08:40 AM
07/04/19 08:40 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
The B/RB was designed in the late 50s and I don't think Chrysler expected them to be pushed as hard as they have been.
Stock production blocks have all kinds of defects and who knows how many hours are on a block when you use one for a build.
This topic has come up many times and I think it was Monte that said with a stock block it's a crap shoot.
I don't push my stuff as hard as other guys, nor do I make as much power. I've got 3 extra 440 cores and 1 400, if it wasn't for that I would probably go Gen3.
twocents
72 Plymouth Roadrunner 11.08@123.25
