Help with left turn signal not blinking
#2672621
07/01/19 04:52 PM
07/01/19 04:52 PM
Posts: 12,250 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Messing with an original 68 Satellite. Nothing has been updated, still has points and single field alternator. Anyway, the left turn signal doesn't flash. Both bulbs light, the brake lights work and the right side flashes like it's supposed to. Before I spent too much time testing stuff, I thought I would ask you guys. Where's the best place to start?
Master, again and still
Re: Help with left turn signal not blinking
[Re: DaveRS23]
#2672648
07/01/19 05:38 PM
07/01/19 05:38 PM
RapidRobert
the brake lights working tells you that it is OK from the connectors behind the drivers kick panel rearward to the rear dual filament bulbs. start by seperating the steering column pull apart connector & ohm the switch. In the neutral stalk position there should be continuity between the white "power in" wire from the brake pedal switch out to the (2) wires (green/brown maybe) for the L/R brake lights which are the same large filaments in the rear 1157 bulbs that are used for the L/R turns signals respectively which is why from the kickpanel harness rearward you are OK. this is what you have during normal brakeing with the stalk in neutral. then see what you get for continuities when you raise the stalk up then down. www.mymopar.com will have diagrams to help you with the colors to sort out the offending left side. & if all good there you can check the continuity between the body half of that harness pull apart connector down to the pull apart connector behind the drivers kick panel. Holler how it turns out. Always a good idea to pull a batt cable before switching the meter to ohms
[Re: DaveRS23]
#2672788
07/01/19 10:13 PM
07/01/19 10:13 PM
RapidRobert
got in it to move out of the way until I had a chance to review what you all had to say and the darned thing started flashing. Good Karma
