Re: lowband aply vb
[Re: Tobbe]
#2671829
06/30/19 09:34 AM
06/30/19 09:34 AM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
There should not be any elements applied in Neutral.
Re: lowband aply vb
[Re: Tobbe]
#2672117
06/30/19 09:04 PM
06/30/19 09:04 PM
Posts: 1,544 CT
mrrandyj
CT
Have a A&A full manual vb with LBA , the rear band aply also in N ist that how they are build? Yes, that is correct. With a low band apply reverse manual valve body the rear band is applied in reverse, neutral, and 1st.
Re: lowband aply vb
[Re: mrrandyj]
#2672201
07/01/19 12:42 AM
07/01/19 12:42 AM
Posts: 248 Sweden
Tobbe
Sweden
Have a A&A full manual vb with LBA , the rear band aply also in N ist that how they are build? Yes, that is correct. With a low band apply reverse manual valve body the rear band is applied in reverse, neutral, and 1st. thanks Randy !
Re: lowband aply vb
[Re: slantzilla]
#2672202
07/01/19 12:43 AM
07/01/19 12:43 AM
Posts: 248 Sweden
Tobbe
Sweden
Do you have to hit the brake button to back up? valvebody have no transbrake
Re: lowband aply vb
[Re: Tobbe]
#2672564
07/01/19 01:56 PM
07/01/19 01:56 PM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
Do you have to hit the brake button to back up? valvebody have no transbrake D'OH!
