Re: Compressor draining [Re: AndyF] #2673359
07/02/19 08:23 PM
07/02/19 08:23 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Originally Posted by AndyF
I have an automatic drain setup on my compressor which I really love. I didn't know anything about them years ago but a guy talked me into putting it on my compressor and now I'm really thankful. It just blows a bit of air out of the bottom drain on the tank every 45 minutes.
It’s an electrical piece ? Does it sense that there’s moisture in the tank?
Re: Compressor draining [Re: dOrk !] #2673369
07/02/19 08:42 PM
07/02/19 08:42 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Originally Posted by Doc Fiberglass
To the guys that drain after every use .... you realize that it takes many hours for the hot compressed air to cool and then water separates from the air
That is why I drain the water out of my compressor in the morning at startup. Some days there is a lot of water in the bottom of the tank, and some days there is very little. I open a gate valve on the bottom of the tank and leave it open until the water quits running out.
I work out of a 2 car garage. I have the water separater and a 90 degree shutoff valve before the quick connect. I use a 100' rubber hose that can reach anyplace in the shop and well past the doors. If needed, I have another 50' hose I can connect to the 1st hose. I can reach the street with my air. I have a 5hp 220 compressor rated at 15CF @ 90 psi with an 80 gal storage tank. Its worked pretty well in my welding shop for the last 15 years. Now that I've retired, I suspect it will last as long as I need it. Gene
Re: Compressor draining [Re: poorboy] #2673381
07/02/19 09:19 PM
07/02/19 09:19 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I just keep my compressor drain cracked enough to bleed the water off and not loose too much water.
Re: Compressor draining [Re: poorboy] #2673515
07/03/19 09:33 AM
07/03/19 09:33 AM
moparx Offline
moparx  Offline
i do the same as gene. "after every use" does not mean the second you shut off the compressor. i also have this same basic setup as he does, but i also have a 60 gallon tank mounted in the roof trusses as an auxiliary tank 40ft away from the compressor. it has it's own drain, and get's drained at start up, but very seldom does it have any more than a few drops of water.
beer
