Brake calipers hanging up ? #2671587
06/29/19 01:57 PM
06/29/19 01:57 PM
Florida STAYcation
dOoC Offline OP
The village idiot's idiot
dOoC  Offline OP
Florida STAYcation
It happened to me the last set of pads I put on .... jsta pushed the piston in with a big C clamp a couple of times. OTHER THAN buying brand new or re-man calipers .... anyone ever try pulling the piston out and 600ing the bore and piston to get that lite corrosion off? .. a bud of mine is having THIS ISSUE right now with his 07 Charger.
Re: Brake calipers hanging up ? [Re: dOoC] #2671662
06/29/19 06:57 PM
06/29/19 06:57 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
We are seeing more and more sticking calipers. The Rams and Dakotas are notorious for it. I have heard that they are easy to rebuild. But I usually just go to the pick-a-part yard and pull obviously remanned ones for $10 a piece.
Master, again and still
Re: Brake calipers hanging up ? [Re: DaveRS23] #2671665
06/29/19 07:01 PM
06/29/19 07:01 PM
md
mopars4ever Offline
mopars4ever  Offline
md
That`s probably why most manufacturers suggest replacing or flush of the brake fluid often that 90% of the people don`t do. I think my VW was every two years or so.
Re: Brake calipers hanging up ? [Re: dOoC] #2671674
06/29/19 07:30 PM
06/29/19 07:30 PM
PA
70Duster Offline
70Duster  Offline
PA
I've only ever had the problem on two Chrysler products; a Dakota and a Grand Cherokee. Both have the phenolic caliper pistons Chrysler insists on using to save a few pennies. Both rear calipers on the Grand Cherokee stuck on trips at different times. One I had to change in the parking lot of an Advance Auto parts store in 95 degree heat halfway to my destination. Never an issue on any other brand of car I owned.
Re: Brake calipers hanging up ? [Re: DaveRS23] #2671693
06/29/19 08:24 PM
06/29/19 08:24 PM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
Good idea ... but how do you easily spot a good reman? Are some you know of painted or powder coated? I’ve cruised a pick part lot and have never seen anything majorly diff.
Re: Brake calipers hanging up ? [Re: mopars4ever] #2671697
06/29/19 08:29 PM
06/29/19 08:29 PM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
Buttt to REALLY FLUSH the system completely.... wouldn’t you have to unattach each caliper and turn it 180 degrees?
I’ll betcha very VERY few people do that !!
Re: Brake calipers hanging up ? [Re: 70Duster] #2671699
06/29/19 08:31 PM
06/29/19 08:31 PM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
So YOU are known to carry around IN YOUR CAR a big 8” C clamp too ?
Re: Brake calipers hanging up ? [Re: dOoC] #2671707
06/29/19 08:53 PM
06/29/19 08:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Big screw driver will back off a piston as well as any C clamp
Re: Brake calipers hanging up ? [Re: dOoC] #2671710
06/29/19 08:59 PM
06/29/19 08:59 PM
Between Houston & Galveston TX
SattyNoCar Online work
SattyNoCar  Online Work
On my '93 Dakota, I was having a problem with the right front hanging up. Being cheap, I ran the piston in and out (just short of popping it out) several times before putting everything back together. When I bled the brakes, I bled until I had clean fluid.
Seems to have worked. Aside from no more heat and smoke, another sign is that the truck picked up a solid 1 - 1.5 MPG. I'll take what I can get!
Oh, and I use a steering wheel puller like this and an old pad to push the piston back in. [Linked Image]
The last time I used a C-clamp, with nothing more than hand strength, it punched thru the back of the caliper. It really didn't feel like I was cranking on it THAT hard. Never had an issue pushing it.
Easier to carry too.
popcorn
John
Re: Brake calipers hanging up ? [Re: dOoC] #2671715
06/29/19 09:07 PM
06/29/19 09:07 PM
Sterling Conn
manymopars Offline
manymopars  Offline
Sterling Conn
Possible defective brake hoses not allowing the brake fluid to return back to the system
Re: Brake calipers hanging up ? [Re: dOoC] #2671717
06/29/19 09:16 PM
06/29/19 09:16 PM
PA
70Duster Offline
70Duster  Offline
PA
It's important to be able to think and improvise when you're on the road and you don't have access to all of your tools. The lug wrench worked well enough to be able to pry the brake pads far enough apart so the old pads could be removed from the old caliper, and the new (rebuilt) caliper already had the piston retracted. No need for an eight inch C clamp.
Re: Brake calipers hanging up ? [Re: 70Duster] #2671740
06/29/19 10:35 PM
06/29/19 10:35 PM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
But what if Yurr on the road and it winds up sticking and SMOKING HOT ? I had that happen twice to me !! I had that C with me because it had stuck slightly before. AND the second time it did it I tried driving through the issue and it WARPED a good solid rotor so bad that I had to buy a new one !
Re: Brake calipers hanging up ? [Re: dOoC] #2671745
06/29/19 10:50 PM
06/29/19 10:50 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The remanned calipers usually have a different finish to the metal. You can typically tell that they are not as old as the vehicle, especially after seeing a few original ones. And then the remanned ones often have a tag or sticker on them. If there are enough of the vehicles to choose from, sometimes you can score shiny, fairly new ones.
Just a few weeks ago, one of the calipers on our work Town and Country started dragging. I had to go to two different yards, but I found a fresh kill Grand Caravan with a nearly new complete front brake job. Calipers, hoses, pads, and rotors all for $40.
But it does take time to find and pull those deals. The only way it probably makes sense for most folks, is if it there were more than just those parts needed.
Re: Brake calipers hanging up ? [Re: DaveRS23] #2671751
06/29/19 11:02 PM
06/29/19 11:02 PM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
Luckily... the two yards I’ve wandered through have the vehicles UP ON welded steel wheels with the regular wheels OFF the car. I’ve never paid detailed attention to the front or rear brake systems - NEVER SEEN AN OBVIOUS NEWER SYSTEM like you did but I will pay better attention next time. Going in there probably next week.
Re: Brake calipers hanging up ? [Re: dOoC] #2671757
06/29/19 11:26 PM
06/29/19 11:26 PM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
Let me add ..., Ive never had a sticking caliper jsta outa the blue. It’s always happened jsta after adding new pads or rotors and/or at the most after driving for maybe 50 or so miles ... THEN it will COAST DOWN like a dream.
Re: Brake calipers hanging up ? [Re: dOoC] #2671763
06/29/19 11:34 PM
06/29/19 11:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Maybe when you install the new pads you are cocking the piston or using your clamp to push the piston back too far. With all the brake jobs I have done I have never had a caliper stick.shruggy
Re: Brake calipers hanging up ? [Re: dOoC] #2671771
06/29/19 11:52 PM
06/29/19 11:52 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Not sure about 07 charger, but being a first generation LX maybe it has the same
2 piston Aluminum PBR calipers with phenolic pistons as the last 2 05 Magnums I've had.
If it does, there's probably not going to be any corrosion, but sometimes the
Plastic pistons develop odd marks in the sides which cause them to stick.
I haven't been able to figure out where the marks come from but they did it twice.
Might even be my fault, I don't know.
Anyway it was the easiest caliper rebuild ever. 4 bucks for seals,
4.50 for new pistons, 99 cents for a copper washer. Take apart and replace the components.
Nothing there to hone and no corrosion at all......
Rich H.
Esse Quam Videri
Re: Brake calipers hanging up ? [Re: ZIPPY] #2671825
06/30/19 09:28 AM
06/30/19 09:28 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I always push the pistons in very slowly to keep contaminates from getting pushed back up the lines. I never had a issue with sticking calipers on any of my modern stuff with the exception of a PT that the right front brake seized up. It was right after I put on some new ceramic pads. It must of had something to due with pushing the piston back for the install of the new pads. I ended up replacing the rotors, pads and calipers, and bleed the brakes to start fresh.
Re: Brake calipers hanging up ? [Re: stumpy] #2671888
06/30/19 11:58 AM
06/30/19 11:58 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Maybe just lucky, maybe something to due with the environment the vehicle lives in. I don't know. I do know that we see sticking calipers on vehicles irregardless of the time frame of brake service or even on ones that have never had the brakes serviced. But it seems some brands tend to have trouble with the hoses, while others tend to have trouble with the calipers. And then some models have few, if any, of these problems. But we see more problems with the calipers it seems on these late model Mopars. But, fortunately, we aren't the only ones experiencing the issues. Which means that we are very likely to find replacement parts for cheap at the pick-a-part yards.
Re: Brake calipers hanging up ? [Re: DaveRS23] #2671911
06/30/19 12:33 PM
06/30/19 12:33 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Would it not be a good idea maybe to open the bleeder screw when you push the piston back to flush out the old fluid and any crap that gathers there?
Kevin
