Re: shifter knob on 1999 3500 5 speed
[Re: dragon]
#2671629
06/29/19 04:43 PM
06/29/19 04:43 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
IF it's like a Dakota the center cap (where the shift pattern is) pops out. There is a lock nut under it. That center cap was very tight on mine and a PITA to put back in. Scarred the knob but I did it over the winter and probably should have waited for a nice warm day to work the cap back in.
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#2671698
06/29/19 08:31 PM
06/29/19 08:31 PM
Posts: 20,677 in a cattle trailer down by th...
Guitar Jones
It's exactly like that. 15mm nut under the center cap.
[Re: Guitar Jones]
#2671755
06/29/19 11:25 PM
06/29/19 11:25 PM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
Okay, how do you remove the shift pattern bezel without wrecking it?
I tried to straighten my bezel, and scratched the end of my knob. I shouldn't have to beat my knob to straighten it? There are a few knobs on Moparts, so someone must have the answer?
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2671791
06/30/19 03:11 AM
06/30/19 03:11 AM
Guitar Jones
I tried to straighten my bezel, and scratched the end of my knob. I shouldn't have to beat my knob to straighten it? There are a few knobs on Moparts, so someone must have the answer? The knob should pliable, if not it's time for a new knob.
