Re: Installing a T5 into an A body?
[Re: Kern Dog]
#2671256
06/28/19 06:16 PM
06/28/19 06:16 PM
Posts: 6,228 nowhere
Sniper
nowhere
An adapter to put an A body shifter on a B/E A833.
[Re: Sniper]
#2671921
06/30/19 12:44 PM
06/30/19 12:44 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I had a 91 Mustang with a T5z in it. While it was a good trans it didn't hold well to much abuse. My Mustang made just shy of 300HP to the tires and weighed 3200lbs with me in it. I broke 3rd gear a few times and once I started to go easy on the 2-3 shift the input gear started breaking, I also broke 5th gear but that was just a snap ring that broke and was a 10 cent fix.
I did beat on the thing but it wasn't that much power, and not that much weight so if you plan to do any spirited driving go easy on the 2-3 shift and keep a stockish clutch in it to help take some shock off of it.
If this is a road course or autocross deal I am sure it will last a good amount. But if you plan to really jam gears learn how to rebuilt it.
68 Barracuda Formula S 340
[Re: Sniper]
#2671994
06/30/19 04:43 PM
06/30/19 04:43 PM
Posts: 704 USA
rftroy
USA
The only way to get the 5 to 600 foot pound torque level, as far as I know, is the G Force kit. But that’s a completely different transmission with new shafts and gears, and about all you use is the original case. Not really an upgrade, but a different transmission. If you really want the T5, sure, go for it. Most all of the other upgrades only get it a little bit above 325 foot pounds of torque max. Which, by the way, you didn’t say what size engine you have in the A body. I would never consider putting a T5 behind a big block.
Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: Sniper]
#2672080
06/30/19 08:06 PM
06/30/19 08:06 PM
Bad340fish
Tulsa OK
All sorts of upgrades out there for the T5 that will allow it to handle 500-600 hp on drag radials.
Nice thing about the T5 is that it is not huge by large, like some of the later stuff. This was a T5Z, which had some upgrades and a different 5th gear ratio over a regular T5. If you spend the money on the super duper T5 upgrades you should just spend that money on a better transmission. Just my .02
[Re: Bad340fish]
#2672083
06/30/19 08:14 PM
06/30/19 08:14 PM
Sniper
nowhere
[Re: Sniper]
#2672263
07/01/19 08:11 AM
07/01/19 08:11 AM
Posts: 1,335 Oregon
earlymopar
I agree. I actually had my (65' SWB pickup) set-up with a T-5 and was wrapping things up when I decided (a little late in the process) to run the numbers on torque and HP and what the T-5 will handle in modified form. Sure there are packages that can handle where I am for both HP and torque but the problems I ran into where that there are other trade-offs. With different gear tooth geometries and cryogenically treated gears, gear noise (whine) is a reality and on a street car, not where I wanted to be. I sold all of my T-5 pieces, had my clutch re-splined and ordered a TKO-600. It was almost identical in cost to the modified T-5, will take the HP and torque in non-modified form and is very quiet in comparison.
- EM
[Re: Sniper]
#2672584
07/01/19 03:04 PM
07/01/19 03:04 PM
Posts: 300 MA
Greg55_99
MA
