Exhaust Maniford 70 vs 71 #2670886
06/27/19 08:45 PM
06/27/19 08:45 PM
Alabama, USA
69DrppTop Offline OP
Alabama, USA
Building a 71 Cuda 340. Want to use 70 TA/AAR exhaust manifolds. Question is what system do I order? Are the header pipes the same for 70 AAR exhaust manifolds as the 340 4-Barrel? Thanks in advance for the assistance.
Re: Exhaust Maniford 70 vs 71 [Re: 69DrppTop] #2670889
06/27/19 08:51 PM
06/27/19 08:51 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
No such thing as AAR / T/A manifolds if that helps?
All 1970 340 Darts, Dusters, & 340 4-barrel Challengers & Cudas used the same type of exhaust manifolds.
(other than some older ones being used up from the prior model year)
All 1968-1970 exhaust manifolds interchange though.
Re: Exhaust Maniford 70 vs 71 [Re: 69DrppTop] #2670890
06/27/19 08:52 PM
06/27/19 08:52 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
71 is different on the passenger side. You can use any 68-70 340 exhaust manifolds from any body style, they are the same.
JB Rhinehart, Realist
A-Body's RULE!
Re: Exhaust Maniford 70 vs 71 [Re: Rhinodart] #2670898
06/27/19 09:15 PM
06/27/19 09:15 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: Exhaust Maniford 70 vs 71 [Re: 69DrppTop] #2670984
06/28/19 07:05 AM
06/28/19 07:05 AM
Alabama, USA
Alabama, USA
Thanks for the quick response. My question was, however --Are the exhaust header pipes the same? In other words, are the exhaust pipes the same where they connect to the exhaust manifolds? Or, do both style exhaust manifolds use the same exhaust pipes/connections? Thanks in advance.
Re: Exhaust Maniford 70 vs 71 [Re: Alaskan_TA] #2670987
06/28/19 07:25 AM
06/28/19 07:25 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Is it true that in terms of flow restriction,
the driver’s side 1992-1993 Magnum V8 exhaust manifold shows more horsepower gain on a dyno,
but that the passenger side the 68-70 exhaust manifold out dynos the 1992-1993 Magnum V8 passenger side?
Maybe Steve Dulich found that result years ago?
Re: Exhaust Maniford 70 vs 71 [Re: 69DrppTop] #2671045
06/28/19 10:26 AM
06/28/19 10:26 AM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
The 340 headpipes are different between the 1970 and 1971 e body applications. See the following link.
http://www.accurateltd.com/70-74-E-Body-Small-Block-318340360-Complete-Exhaust-Systems-_p_239.html
Order the headpipes that correspond with the exhaust manifolds being used. The 1970 340 exhaust manifolds , (49,53 castings)
had welded hp flanges on the headpipes and used gaskets. The 1971 headpipes used a floating flange and ball joint connection arrangement that did not use a gasket between the manifolds (623,621 castings) and the headpipes. Hope this answers your question.
Re: Exhaust Maniford 70 vs 71 [Re: 69DrppTop] #2671064
06/28/19 11:09 AM
06/28/19 11:09 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Why would that even matter? Aren't you going to have a muffler shop custom-bend a new system?
Re: Exhaust Maniford 70 vs 71 [Re: Tom Swope] #2671325
06/28/19 09:30 PM
06/28/19 09:30 PM
Alabama, USA
Alabama, USA
Thanks. That answers the question. I got it from here. Cheers...….
