Page 2 of 3 1 2 3
Re: 440 struggles past 4,000 rpm [Re: TonyS451] #2671031
06/28/19 10:00 AM
06/28/19 10:00 AM
California, U.S.A.
Torquemonster440 Offline OP
California, U.S.A.
Originally Posted by TonyS451
I know you found some metal flakes in the carb bowl, did you check your fuel filter as well? I know you said it holds steady fuel pressure, but worth a check.
It's a fairly large "high flow" filter.. but, yes.. I should check it..
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
Re: 440 struggles past 4,000 rpm [Re: lewtot184] #2671033
06/28/19 10:01 AM
06/28/19 10:01 AM
California, U.S.A.
California, U.S.A.
[quote=lewtot184]going up "4 steps" on jetting could be a bunch; especially if your not figuring jet area; and using a carb with a sensitive booster. too fat kills power/rpm. [/quote
I jetted up 4 sizes anticipating much more airflow with the new heads. Even after going up those four steps, the plugs still look lean.
Re: 440 struggles past 4,000 rpm [Re: Torquemonster440] #2671040
06/28/19 10:10 AM
06/28/19 10:10 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Originally Posted by Torquemonster440
Originally Posted by GTX MATT
Which 850 Annular carb is it? 9380?
Yes, it's the 9380. And yeah I did follow up on Holley's website.. looks like it should of had 78's all the way around when new.
They came with 78s, and 78s are RICH in my experience. I'm surprised your plugs look lean, but the air bleeds may have been modified.
Re: 440 struggles past 4,000 rpm [Re: GTX MATT] #2671053
06/28/19 10:37 AM
06/28/19 10:37 AM
California, U.S.A.
California, U.S.A.
Supposedly the carb was new.. "never installed" when I bought it, but obviously someone fooled with it at some point.. because it had 82's on the primary side when I brought it home.
Re: 440 struggles past 4,000 rpm [Re: Torquemonster440] #2671090
06/28/19 11:42 AM
06/28/19 11:42 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
airflow increase doesn't always mean more jet area. airflow increase will up the vacuum signal to those boosters and it may at times dictate more control on the fuel side. i'd put the carb back to factory specs and then make "as needed" changes.
Re: 440 struggles past 4,000 rpm [Re: Torquemonster440] #2671094
06/28/19 11:53 AM
06/28/19 11:53 AM
NW Illinois
MoonshineMattK Offline
NW Illinois
I personally will never try to tune a carburetor without an air fuel ratio sensor again. My advice would be to get one. Even if it doesn't help with this particular problem you will have a much easier time jetting the carb with the gauge.
Hope you get it solved
Re: 440 struggles past 4,000 rpm [Re: Torquemonster440] #2671097
06/28/19 11:56 AM
06/28/19 11:56 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
you should put the carb to baseline, it probably needs to go down on the prim jets. once you get the miss sorted maybe you can play with removing the secondary side power valve and upping the jets 6-8 steps...
also, i've seen pics of those carbs new or NOS without air bleeds in some positions, you should check that.
Re: 440 struggles past 4,000 rpm [Re: krautrock] #2671102
06/28/19 12:04 PM
06/28/19 12:04 PM
California, U.S.A.
California, U.S.A.
also, i've seen pics of those carbs new or NOS without air bleeds in some positions, you should check that. [/quote]
All good advice, I will take it back to base line and and work from there.. also, what has me stumped is, there is no noticable "miss".. surge or even a loss in power, it's just that it doesn't RPM easily past 4k in high gear.
Re: 440 struggles past 4,000 rpm [Re: Torquemonster440] #2671116
06/28/19 12:39 PM
06/28/19 12:39 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I have the same carb, mine did not come with any restrictions on the IABs on the primary side. Square jetted at 78 out of the box it pinned my wideband at 10:1 (lowest it reads) at WOT. If you've got more jet I would suspect you are way rich at WOT if yours is of a similar vintage to mine and has the same calibrations. 74s or 75s square was a much closer starting point for me with the stock passage calibrations, still way rich everywhere except WOT though.
I would go to 78 square and see what that gets you. With 78 square this carb will cruise with an AFR of less than 12.0. What is you current jetting? If you are at 86/82 I'd suspect you could be on the verge of a rich missfire.
Re: 440 struggles past 4,000 rpm [Re: GTX MATT] #2671128
06/28/19 01:16 PM
06/28/19 01:16 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
All due respect you have more of a mechanical (fuel pump, pushrod, restriction, valve springs etc.) than you do a "Jetting" problem. Changing jets are not going to solve your problem.Something mechanical is causing it to run out of fuel at 4000 RPM's.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: 440 struggles past 4,000 rpm [Re: ChrgrCuda] #2671132
06/28/19 01:21 PM
06/28/19 01:21 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
this could be true, but I believe baselining the carb could eliminate it as a problem.
Re: 440 struggles past 4,000 rpm [Re: krautrock] #2671141
06/28/19 01:41 PM
06/28/19 01:41 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If you have a friend with a “known good” carb you can borrow....... you could try it and see if the problem went away or not.
If it acts the same, it’s unlikely a carb issue(and I don’t think it is).
Re: 440 struggles past 4,000 rpm [Re: fast68plymouth] #2671200
06/28/19 03:59 PM
06/28/19 03:59 PM
California, U.S.A.
California, U.S.A.
Yeah, unfortunately I don't think it's the carb either, although taking it back to base line won't hurt.
Dwayne, you suspect the springs ? Even with my mild cam and rockers? And only at 4,000, rpm ? I' m gonna dig into the cap and rotor first and see if that helps.
Thanks for all the input and ideas everyone.👍
Re: 440 struggles past 4,000 rpm [Re: fast68plymouth] #2671211
06/28/19 04:15 PM
06/28/19 04:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
From what your saying and the plugs show it(if your reading right) it running
lean.. now that can be a short pump rod.. that would only allow X amount
of fuel to enter and run lean
Re: 440 struggles past 4,000 rpm [Re: Torquemonster440] #2671213
06/28/19 04:18 PM
06/28/19 04:18 PM
So. Burlington, Vt.
So. Burlington, Vt.
If it noses over at 4K in every gear, it’s not fuel related.
Which is why I asked if the recovery was instant after a gear change.
If the recovery after the shift is instant...... it’s ignition or mechanical.
I had a very similar situation many years ago after a cam swap, but at about 5k instead of 4K.
Old cam revved over 6k easily....... new cam was totally flat at 5k.
Not a bunch of drama....... no popping, didn’t really surge or carry on....... just ran into a wall.
You could pretty much just hold your foot on it in 2nd...... it would just maintain 5k.
The instant you pulled 3rd....... it just took off again...... til 5k.
This was in like 1986, and I was pretty puzzled by it. Thought it was fuel..... hooked up a gauge I could see while driving...... never dropped below 4psi........ and the gauge never changed when you went from flat at 5k in 2nd to pulling hard in 3rd.
I was buying speed parts from one of the local engine shops...... took the owner for a ride.
He agreed it didn’t really feel or act like float........ but since I found nothing else wrong he suggested adding a shim under the springs and see if it changed.
So, I added a .060 under each spring.
Totally cured it........ it would rev as high as I wanted after that(63-6500).
At one point I also had an issue with the rev limiter on a MSD digital 6 box coming in at 5k.
It tested perfect with an msd ign tester, but with the motor running, any setting over 5k...... still engaged the limiter at 5k....... even in neutral.
Rolled the knobs back to zero....... motor revved fine.
Re: 440 struggles past 4,000 rpm [Re: Torquemonster440] #2671225
06/28/19 04:49 PM
06/28/19 04:49 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I put an engine together long ago that wouldn't go past 3000. Turns out it was pistons hitting valve that I didn't check after installing a bigger cam. I don't know if your new heads change how close the pistons come to the valves, or if you checked that. My little engine had an unfortunate demise as I was trying to figure out why it wouldn't go past 3k.
Re: 440 struggles past 4,000 rpm [Re: Exit1965] #2671227
06/28/19 05:03 PM
06/28/19 05:03 PM
houston, mo
johnnmo Offline
johnnmo  Offline
houston, mo
Early 70,s, I had a 427 chevy that did that. about 4500 and it was done. Any gear, everytime.
Valve springs were weak.
That motor had a lot of miles and overheated a few times.
Re: 440 struggles past 4,000 rpm [Re: fast68plymouth] #2671235
06/28/19 05:18 PM
06/28/19 05:18 PM
Washington
madscientist Offline
Washington
LOL. I had a cheap customer who just didn't want to change anything, or even check most any thing. He brought in a 6 cylinder ford head and said, kiss the seats with a stone and slam it back together. Don't check it for cracks, don't check the surface, just do it.
A week later he drives the ruck over and it's barely running. The springs were so weak anything more than idle speed or slightly higher RPM and the lifter would pump up and open some valves! He wanted me to "shim" it. I said get bent. It either comes off and gets done right or take your garbage somewhere else.
After that, I never let him dictate what i did whether he was paying or not.
Re: 440 struggles past 4,000 rpm [Re: madscientist] #2671265
06/28/19 06:26 PM
06/28/19 06:26 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
What ignition box and coil are you using? Are you running a ballast resistor?
Re: 440 struggles past 4,000 rpm [Re: sgcuda] #2671281
06/28/19 07:02 PM
06/28/19 07:02 PM
California, U.S.A.
California, U.S.A.
Orange box with a ballast resistor. An Accell 80410-C ignition coil.. the coil is showing higher than spec resistance 1.8 ohms vs spec: 1.4 ohms on the primary side. And 10,200 ohms vs spec:9,200 ohms on the secondary side. Not sure if that's enough's to cause this issue though?
Page 2 of 3 1 2 3
