Ridge reamers?
#2670718
06/27/19 02:06 PM
06/27/19 02:06 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Yes, I actually want to know about ridge reamers. I know it's not the most popular thing to do but I'd like to shave the .002" ridge off the tops of the otherwise straight and smooth bores in this 440. I already have pistons and rings that are within tolerance for this engine and don't feel the need to drop the funds to bore it and buy new stuff.
Setting up the block in my mill would be a major PITA since I'm not set up for engine work. This is a low power application and should be fine with reaming. Slamming rings into ridges is not on my favorites list.
What kind of reamers have you guys used and how well did they work? I know the results will be no better than the person doing the job.
Re: Ridge reamers?
[Re: feets]
#2670724
06/27/19 02:16 PM
06/27/19 02:16 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
I used them years ago until I realized that the ridge you are cutting down is the actual bore size and what you are doing is cutting that down to the worn out size of the bore. So your bores are not straight. if its just a rebuild just hone it with a ball hone and be done..
JAKES AUTOMOTIVE
Re: Ridge reamers?
[Re: feets]
#2670727
06/27/19 02:18 PM
06/27/19 02:18 PM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
I just used whatever the parts store had for rent at the time, which I think was a Lisle brand. Worked just fine.
As long as only the ridge is removed and nothing more, there is nothing wrong with them.
It's definitely very bad to make the top of the bore a different/larger dimension than the bottom and create more taper....however, if it can't be disassembled easily with the ridge in the way...for instance....you have to do what you have to do. Hand hone it afterwards.
The main problem is folks not understanding it and taking too much material off, but you won't have any problems.
Rich H.
Esse Quam Videri
Re: Ridge reamers?
[Re: feets]
#2670745
06/27/19 02:57 PM
06/27/19 02:57 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the top ring in the new pistons is below the ridge, no need the remove the ridge.
Re: Ridge reamers?
[Re: JAKE68]
#2670793
06/27/19 05:12 PM
06/27/19 05:12 PM
feets
Senior Management
Senior Management
Irving, TX
I used them years ago until I realized that the ridge you are cutting down is the actual bore size and what you are doing is cutting that down to the worn out size of the bore. So your bores are not straight. if its just a rebuild just hone it with a ball hone and be done.. Correct, I will be cutting down a standard bore to approximately .004" larger in diameter. The remainder of the bore is still straight (less than .001" out of round) in each hole. The forged pistons I have are sufficient to work with the bore in it's worn diameter. The new rings gap properly as well. If I intended to put together a big power engine I'd bore and hone. However, I have parts on hand that are compatible and am looking for little more than stock power. This is one situation where the "dingle ball rebuild" is acceptable. The idea is to remove no more than necessary and sneak up on the final dimension. Being a machinist, I'm fairly certain I can make that happen.
Re: Ridge reamers?
[Re: feets]
#2670796
06/27/19 05:19 PM
06/27/19 05:19 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
I would hone the ridge out, not ream it based on my past problems with using ridge reamers A ball hone won't do that either
Re: Ridge reamers?
[Re: Craig J]
#2670858
06/27/19 07:23 PM
06/27/19 07:23 PM
Porter67
I like to go 15 minutes dry vs 30 with some lube. Really why even bore, just hone a bit longer. :0 you just need to hone for about 30 minutes after boring You mean the portable block boring tool? They work great for cleaning up deep scratches from broken rings, you just need to hone for about 30 minutes after boring to clean up the work.
Re: Ridge reamers?
[Re: ZIPPY]
#2670895
06/27/19 09:00 PM
06/27/19 09:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The main problem is folks not understanding it and taking too much material off, but you won't have any problems. This is the same brand I own.. I havent used it in about 50years now.. back then the blocks were softer thats why we had to use it.. back then you couldnt pull the pistons out without using the ridge reamer
Re: Ridge reamers?
[Re: jwb123]
#2670995
06/28/19 07:40 AM
06/28/19 07:40 AM
RapidRobert
I was told (read it somewhere) that a new top ring might hit the ridge (right or wrong) with it still there. If you use one, put the box wrench on it & pull the cutter toward you as opposed to pushing it & change your position around the eng frequently so that you are pulling it at a good comfortable angle & press down on it at all times so it stays concentric down on the deck. It will never cut dead evenly so frequent fingernail checks & never go past flush at any point in the circumference which will likely leave a very slight ridge at some point but that is as good as it can get.
Re: Ridge reamers?
[Re: B1MAXX]
#2671126
06/28/19 01:11 PM
06/28/19 01:11 PM
Posts: 5,163 CT
GTX MATT
CT
I think all you need to really know is don't take off ANY more material than you need, and as noted pull it towards you and move around. You don't want to apply too much pressure, and don't try to cut too much at once.
Have you measured what your piston to wall clearance is going to be with the forged pistons? Stock PTW was supposed to be .0025-.0035. If you're running TRWs they can require about .007 anyway, if you think you're worn about .004 it might make sense to get a hone from a shop for $100 or so, you might be straight and square at .007.
Re: Ridge reamers?
[Re: B1MAXX]
#2671266
06/28/19 06:27 PM
06/28/19 06:27 PM
Cab_Burge
I bought a Lysle (SP?) brand professional adjustable tension cylinder hone in the early to mid 1970s along with several BHJ steel torque plates for wedges,,426 hemi and L.A. motors, I spent one entire afternoon honing a 340 motor with both heads bolted and torque down honing from the crankcase side of the block with that mechanically adjustable tension hone with a 5/8 Craftsman electric drill motor, I was honing it to get two shadows out of the cylinder walls caused by the outer head bolts and the block not being bored and hone with a plate originally That was the last time I tried to remove more than .0020 or more with that hone, way cheaper and easier to pay the machine shop the $40.00 for torque plate honing back then than spend 6.0+ hours doing it myself
Re: Ridge reamers?
[Re: Cab_Burge]
#2671279
06/28/19 06:58 PM
06/28/19 06:58 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
A .002”(two thou) ridge?
10-15 seconds with a ball hone and some wd-40 in the bores ...... done.
Re: Ridge reamers?
[Re: fast68plymouth]
#2671324
06/28/19 09:29 PM
06/28/19 09:29 PM
Cab_Burge
10-15 seconds with a ball hone and some wd-40 in the bores ...... done. The divots, shadows, in the top of the cylinders needed right at .0020 removed to get rid of them
Re: Ridge reamers?
#2671437
06/29/19 09:04 AM
06/29/19 09:04 AM
Posts: 1,993 Apollo, PA.
B1MAXX
Apollo, PA.
10-15 seconds with a ball hone and some wd-40 in the bores ...... done. You won't take a ridge out with a ball one ...It will look like you did though, look real pretty. It hits all the low spots. To the original post all of this will work though. A properly used ridge reamer will yield the best home results for removing the ridge and removing the shadows.
