Re: 2006 300C: Temp bypass PS possible?
[Re: kowalski440]
#2671096
06/28/19 11:55 AM
06/28/19 11:55 AM
Posts: 19,555 north of coder
moparx
the place where the pressure/return lines are bolted to the rack often times collect dirt and crud, causing the lines to rust out over time. i have fixed quite a few leaks in that spot over the years. it looks like the rack is leaking there, but it turns out to be one, or both lines. what is frustrating, is the lines look perfect going to the rack and pump. remove the clamp, and the lines look terrible ! hope this helps.
