Dash Light Issue #2670608
06/27/19 10:55 AM
06/27/19 10:55 AM
Tony440 Offline OP
Tony440  Offline OP
Hello, I have a 67 Coronet R/T. When I turn the dimmer switch to brighten the dash lights, the dash lights will go out. If I slowly turn the dimmer switch back and forth I can sometimes find a sweet spot where the dash lights will be bright enough. Would this be a problem with the dimmer switch or a voltage regulator in the dash? Thanks.
Re: Dash Light Issue [Re: Tony440] #2670617
06/27/19 11:21 AM
06/27/19 11:21 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Most likely the dimmer resistor deally in headlight switch. Very common on these oldies. You could try rotating switch back and forth to clean contact somewhat.
Re: Dash Light Issue [Re: buildanother] #2670630
06/27/19 12:02 PM
06/27/19 12:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Definitely a dimmer problem. The dash voltage regulator has nothing to do with the lights. It just reduces 12v to 5v for the gauges.
Re: Dash Light Issue [Re: stumpy] #2670649
06/27/19 12:46 PM
06/27/19 12:46 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
we have had good luck using the following product. Spray on and run the dimmer back and forth several times. Repeat if you'd like beer
LINKY
Re: Dash Light Issue [Re: Tony440] #2670651
06/27/19 12:49 PM
06/27/19 12:49 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Do the lights go out when you try to go full bright? Then usually the resistor wire is broken at that spot. If cleaning doesn't work and the wire is broken it can be soldered for a some what repair.
Re: Dash Light Issue [Re: 71birdJ68] #2670980
06/28/19 06:10 AM
06/28/19 06:10 AM
Tony440 Offline OP
Tony440  Offline OP
Thanks for the replies. Yes the dash lights go out when I try to get them to go full bright. I'll take a look at the contacts and resistor.
