70 B-body drum master cylinder bore? #267047
03/26/09 08:51 AM
03/26/09 08:51 AM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
Is the bore on a 70 B body master cylinder 1" or 1" 1/32? i want to rebuild mine. manual drum brakes.
Re: 70 B-body drum master cylinder bore? [Re: satgtx] #267048
03/26/09 11:30 AM
03/26/09 11:30 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
They are 1" bore.
'71-on master cylinders were 1-1/32". Since they all have the same 4 bolt mounting flange and outlet threads, it is not uncommon to see '71 up master cylinders that have been installed on earlier cars, so make sure yours is actually the '67-'70 style.
Original '67-'70 drum brake master cylinders had a bolt on style filler cap.
Re: 70 B-body drum master cylinder bore? [Re: Mastershake340] #267049
03/26/09 12:26 PM
03/26/09 12:26 PM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
Mastershake, thank you for the answer, yes it is the original MC.
