Re: Electric power steering pump
[Re: crash520]
#2670036
06/26/19 04:51 AM
06/26/19 04:51 AM
Posts: 145 Australia
dodgy
Australia
Maybe the earlier pumps were controlled by the canbus but im sure these Ts models are pressure sensitive, you can here this pump ramp up speed when he turns the wheel. https://youtu.be/Yy6oQPJJ2qYThat said it still wouldn't lower the pressure (to what you want) at full lock but will idle back in the non demand steering. I don't know maybe I'm not seeing it right.
[Re: dodgy]
#2670358
06/26/19 07:19 PM
06/26/19 07:19 PM
Posts: 247 Brisbane Australia
crash520
Brisbane Australia
Maybe the earlier pumps were controlled by the canbus but im sure these Ts models are pressure sensitive, you can here this pump ramp up speed when he turns the wheel. https://youtu.be/Yy6oQPJJ2qYThat said it still wouldn't lower the pressure (to what you want) at full lock but will idle back in the non demand steering. I don't know maybe I'm not seeing it right. Yeah I’m not sure either mate, I just don’t know that much about those pumps and I haven’t got the time or money to go splashing it around on a whim, nor have I got the $1400 old mate on the north side wants for his kit
[Re: crash520]
#2670594
06/27/19 10:18 AM
06/27/19 10:18 AM
Posts: 4,451 Michigan
MarkZ
Worthy
Worthy
What about a GM type II pump with a remote reservoir? That would save a considerable amount of space up front. If you want to dial in the flow and pressure Turn One has hardware that can help.
[Re: MarkZ]
#2670817
06/27/19 06:09 PM
06/27/19 06:09 PM
crash520
Brisbane Australia
What about a GM type II pump with a remote reservoir? That would save a considerable amount of space up front. If you want to dial in the flow and pressure Turn One has hardware that can help. Mark is that GM pump driven by the crank? If so that my issue, as such, I’m looking at that ability to remove the pump from the engine. Heist do a ps pressure bypass valve but I’m thinking the electric pump would be running flat out the whole time with this fitted, IDK, I’m just spit balling atm , thanks for your input though
[Re: crash520]
#2677496
07/15/19 08:10 AM
07/15/19 08:10 AM
Posts: 640 Graz, Austria
DGS
Graz, Austria
crash have you got a pump , bloke in Brisbane was selling TS Astra pumps fairly cheap. Dodgy, yes I saw his adds, according to a PS guy on the Northside the Astra TRW pumps can’t be pressure controlled, so he says, they run around 1400 psi and I’d like it around 800-900 psi, he has a pump kit out of a European car (mini, bmw) that can be, but I’m thinking it’s a sales pitch and I don’t know that much about ps pumps. The Astra pumps are cheap, his conversion pump is $1400😳 and that a little more than I would be prepared to pay I looked into this a few months ago. There are two Astra pumps: the earlier one (TRW I) puts out about 100 bar (1450psi) whereas the later (TRW II) is around 80 bar (1160 psi). Furthermore the earlier TRW II pumps are pressure controlled (or actually electrical load sensed) and the later ones require an ECU input. You have to look for an early TRW II pump. These pumps came in a variety of different models not only in Astra models. The benefit of these pumps is speed sensitive power steering (high speed --> low steering input --> low electrical load --> low PS assist)! btw. if the pressure is still too high you can buy this little device that allows you to adjust the pressure: https://www.speedwaymotors.com/Heidts-PS-101-Adjustable-Power-Steering-Valve,14895.htmlHave a close look at the connectors (the old pump has just one connection - the newer pump has several). This is the pump you want: That's the newer pump you should avoid: ![[Linked Image]](https://www.callparts.de/sites/default/files/productimages/LRP31000127742068/2627990.jpg) btw. have you looked at Mercedes pumps? W168 pumps (A 168 466 04 01) are 71 bar (1030 psi) and W414 (A 414 466 00 01) pumps are 81 bar (1175 psi). ![[Linked Image]](https://2.bp.blogspot.com/-fqbud_P_Nbs/Vo1GPLBWp_I/AAAAAAAAA44/0Mz58wDt5N0/s1600/DSC00001.JPG)
[Re: Jim_Lusk]
#2679967
07/22/19 03:08 AM
07/22/19 03:08 AM
DGS
Graz, Austria
Basically all ECU controlled units should be avoided as you would need a computer and several sensors to control the pump. Signal to the pumps is most likely a PWM (pulse width modulated) signal.
IMO the easiest solution for invisible A/C would be a low mount compressor on the passenger side and an electric fuel pump.
[Re: DGS]
#2681436
07/25/19 10:47 PM
07/25/19 10:47 PM
crash520
Brisbane Australia
crash have you got a pump , bloke in Brisbane was selling TS Astra pumps fairly cheap. Dodgy, yes I saw his adds, according to a PS guy on the Northside the Astra TRW pumps can’t be pressure controlled, so he says, they run around 1400 psi and I’d like it around 800-900 psi, he has a pump kit out of a European car (mini, bmw) that can be, but I’m thinking it’s a sales pitch and I don’t know that much about ps pumps. The Astra pumps are cheap, his conversion pump is $1400😳 and that a little more than I would be prepared to pay I looked into this a few months ago. There are two Astra pumps: the earlier one (TRW I) puts out about 100 bar (1450psi) whereas the later (TRW II) is around 80 bar (1160 psi). Furthermore the earlier TRW II pumps are pressure controlled (or actually electrical load sensed) and the later ones require an ECU input. You have to look for an early TRW II pump. These pumps came in a variety of different models not only in Astra models. The benefit of these pumps is speed sensitive power steering (high speed --> low steering input --> low electrical load --> low PS assist)! btw. if the pressure is still too high you can buy this little device that allows you to adjust the pressure: https://www.speedwaymotors.com/Heidts-PS-101-Adjustable-Power-Steering-Valve,14895.htmlHave a close look at the connectors (the old pump has just one connection - the newer pump has several). This is the pump you want: That's the newer pump you should avoid: ![[Linked Image]](https://www.callparts.de/sites/default/files/productimages/LRP31000127742068/2627990.jpg) btw. have you looked at Mercedes pumps? W168 pumps (A 168 466 04 01) are 71 bar (1030 psi) and W414 (A 414 466 00 01) pumps are 81 bar (1175 psi). DGS, this is all good information thank you, I haven’t had a lot of time to delve into it further however I’m sure it’s not such a bad plan and a worthy option if it can be made work, the original Mopar pumps from memory run 900-1300 psi, and are non load sensored obviously. The guys out here with the GM Astra/Opel pumps simply wire the signal wire to 12V and give it full signal. I have one of those bypass regs laying about. I really like the idea, and apparently the Late model Mini pump can be regulated, they are just expensive out here and for those who need front engine space or to clean up an engine bay it’s the go to, just need someone with smarts and time to work it out
[Re: Jim_Lusk]
#2681931
07/28/19 05:07 AM
07/28/19 05:07 AM
DGS
Graz, Austria
I'm going to look into the programming of an Arduino or Raspberry Pi (my nephew has some experience with the Raspberry). Could also program the computer to track/monitor/control other things as well (not sure what yet, but...). Would be a great idea to incorporate speed signal as input to make it speed sensitive (lots of OEMs have speed sensitive steering): low speed, high assist, high speed, low assist.
[Re: BigBlockMopar]
#2682185
07/28/19 11:30 PM
07/28/19 11:30 PM
Posts: 18,679 Fresno, CA
Jim_Lusk
Fresno, CA
IMO, about the only simple ways to get to read the speed on an older car without CAN stuff is to feed off the transmission's governor oil-pressure, or install a combined cable and electric pulse sender on the transmission's speedo-connector. That would be the plan. Right now my job is to get the car running so I'll probably just mount the mechanical pump and pick up an electric pump later and play around with it.
