Motor plate or Solid Mounts? #2669828
06/25/19 03:38 PM
06/25/19 03:38 PM
New York, USA
Chargerfan68 Offline OP
New York, USA
Is approx 750 hp (500” with 4.15” stroke) too much to run solid mounts? Too much stress for the block in that mount area. Or, it is relatively safe and others have done it here for years?
Re: Motor plate or Solid Mounts? [Re: Chargerfan68] #2669833
06/25/19 03:47 PM
06/25/19 03:47 PM
AndyF Offline
AndyF  Offline
All depends on how you are using the car. If you have a stick shift and are launching the car hard off the line round after round then I'd go with a motor plate. If it is a street car I'd use rubber mounts. Somewhere in between you just have to pick your poison.
Re: Motor plate or Solid Mounts? [Re: AndyF] #2669845
06/25/19 04:52 PM
06/25/19 04:52 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The thought of a motor plate is good but in actual use I didn't like it. Maybe you need those poly lock or Schmacher mounts. You know, the kind in urethane and if it breaks, the steel catches it.
2011 Drag Pak Challenger
Re: Motor plate or Solid Mounts? [Re: rickseeman] #2669855
06/25/19 05:21 PM
06/25/19 05:21 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Those mounts are only good for stockish builds, barely.....I like a motor plate myself. But friends on my run a set of new stock mounts and that Mancini helm jointed adjustable brace for a mainly street driven car.
Re: Motor plate or Solid Mounts? [Re: rickseeman] #2669859
06/25/19 05:36 PM
06/25/19 05:36 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Can you expand on this thought? This was something I went back and forth and eventually went motor plate (stick shift, nitrous).
I ended up going motor plate this time because with the oil pan/lines, headers and steering/torsion bars it was easier to get the mounts out of the way. The motor plate occupies space (66 b-body) that was for the most part unused so gaining any room in the devils matrix (that area between the block, headers, steering box and oil pan) was of great benefit. I would think doing away with torsion bars and going to a rack would solve some of those issues too.
Re: Motor plate or Solid Mounts? [Re: Jeremiah] #2669860
06/25/19 05:43 PM
06/25/19 05:43 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I ran the Schumakers for a few years , then they melted and collapsed
I now have the bolt through type , Mancini and 440 Source sell them
https://www.manciniracing.com/maheduenmo.html
PLUS I use a torque strap from K fram to motor mount bracket on block
https://www.alllifting.com.au/colle...products/rated-rigging-screw-jaw-and-jaw
No dramas for the last year or so . I do run a transbrake .
Not sure I want to go to a plate for daily street use .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Motor plate or Solid Mounts? [Re: tex013] #2669870
06/25/19 06:07 PM
06/25/19 06:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I love my motor plate.. car runs very smooth.. I dont feel any vibrations
at all even in OD
wave
Re: Motor plate or Solid Mounts? [Re: MR_P_BODY] #2670005
06/25/19 11:23 PM
06/25/19 11:23 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Been using a plate for 25 years AND a spool.You know the history whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Motor plate or Solid Mounts? [Re: hemi-itis] #2670077
06/26/19 08:24 AM
06/26/19 08:24 AM
an8sec70cuda Offline
I run a motorplate and love it. It makes everything easier...engine R&R, clearance for headers/oiling system, and a place to mount everything up front.
The vibration difference is minimal IMO.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Motor plate or Solid Mounts? [Re: an8sec70cuda] #2670103
06/26/19 09:41 AM
06/26/19 09:41 AM
hemi-itis Offline
hemi-itis  Offline
40 years ago we just used a chain with a turnbuckle to hold the drivers side down with stock rubber motor mounts!...LOL
Re: Motor plate or Solid Mounts? [Re: hemi-itis] #2670124
06/26/19 10:35 AM
06/26/19 10:35 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Since my 63 is a street car I run a solid steel mount on the drivers side that you can barely see under the # 1 plug wire. I also left the chain on for back-up. On the pass side I run the standard rubber eng mount. This has worked fine for me for many years. I race it once or twice a year usually. Ron
Re: Motor plate or Solid Mounts? [Re: 383man] #2670173
06/26/19 12:17 PM
06/26/19 12:17 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Diapers are easier with plates also.
Re: Motor plate or Solid Mounts? [Re: Jeremiah] #2670260
06/26/19 03:14 PM
06/26/19 03:14 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The thought of it is freeing up the space to have better access to almost everything under the car. It just makes it easier to work under there. And it gives you a place to mount stuff too.
