Motor plate or Solid Mounts?
#2669828
06/25/19 03:38 PM
06/25/19 03:38 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Is approx 750 hp (500” with 4.15” stroke) too much to run solid mounts? Too much stress for the block in that mount area. Or, it is relatively safe and others have done it here for years?
Re: Motor plate or Solid Mounts?
[Re: AndyF]
#2669845
06/25/19 04:52 PM
06/25/19 04:52 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
The thought of a motor plate is good but in actual use I didn't like it. Maybe you need those poly lock or Schmacher mounts. You know, the kind in urethane and if it breaks, the steel catches it.
2011 Drag Pak Challenger
[Re: rickseeman]
#2669855
06/25/19 05:21 PM
06/25/19 05:21 PM
Posts: 12,393 Taxes & Virus's R-US, NY
Dragula
The thought of a motor plate is good but in actual use I didn't like it. Maybe you need those poly lock or Schmacher mounts. You know, the kind in urethane and if it breaks, the steel catches it. Those mounts are only good for stockish builds, barely.....I like a motor plate myself. But friends on my run a set of new stock mounts and that Mancini helm jointed adjustable brace for a mainly street driven car.
[Re: rickseeman]
#2669859
06/25/19 05:36 PM
06/25/19 05:36 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
The thought of a motor plate is good but in actual use I didn't like it. Maybe you need those poly lock or Schmacher mounts. You know, the kind in urethane and if it breaks, the steel catches it. Can you expand on this thought? This was something I went back and forth and eventually went motor plate (stick shift, nitrous). I ended up going motor plate this time because with the oil pan/lines, headers and steering/torsion bars it was easier to get the mounts out of the way. The motor plate occupies space (66 b-body) that was for the most part unused so gaining any room in the devils matrix (that area between the block, headers, steering box and oil pan) was of great benefit. I would think doing away with torsion bars and going to a rack would solve some of those issues too.
[Re: tex013]
#2669870
06/25/19 06:07 PM
06/25/19 06:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I love my motor plate.. car runs very smooth.. I dont feel any vibrations at all even in OD
[Re: MR_P_BODY]
#2670005
06/25/19 11:23 PM
06/25/19 11:23 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Been using a plate for 25 years AND a spool.You know the history
[Re: hemi-itis]
#2670077
06/26/19 08:24 AM
06/26/19 08:24 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I run a motorplate and love it. It makes everything easier...engine R&R, clearance for headers/oiling system, and a place to mount everything up front. The vibration difference is minimal IMO.
[Re: an8sec70cuda]
#2670103
06/26/19 09:41 AM
06/26/19 09:41 AM
hemi-itis
40 years ago we just used a chain with a turnbuckle to hold the drivers side down with stock rubber motor mounts!...LOL
[Re: Jeremiah]
#2670260
06/26/19 03:14 PM
06/26/19 03:14 PM
rickseeman
Stuttgart, Arkansas
The thought of a motor plate is good but in actual use I didn't like it. Maybe you need those poly lock or Schmacher mounts. You know, the kind in urethane and if it breaks, the steel catches it. Can you expand on this thought? This was something I went back and forth and eventually went motor plate (stick shift, nitrous). I ended up going motor plate this time because with the oil pan/lines, headers and steering/torsion bars it was easier to get the mounts out of the way. The motor plate occupies space (66 b-body) that was for the most part unused so gaining any room in the devils matrix (that area between the block, headers, steering box and oil pan) was of great benefit. I would think doing away with torsion bars and going to a rack would solve some of those issues too. The thought of it is freeing up the space to have better access to almost everything under the car. It just makes it easier to work under there. And it gives you a place to mount stuff too.
