Lower control arm Pin to K Frame
#2669361
06/24/19 01:25 PM
06/24/19 01:25 PM
Posts: 15,311 Omaha Ne
TJP
Omaha Ne
Have a 68 Dart with a lower control arm pin that does not want to tighten down. I believe these are tapered and supposed to "press in" to the K frame as you tighten it down. Correct ? The K frame and pin both appear fine with no noticeable wear. Any comments /suggestions/ fixes ?? Thanks
Re: Lower control arm Pin to K Frame
[Re: TJP]
#2669393
06/24/19 02:25 PM
06/24/19 02:25 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Chase the threads on the pin so the nut will go all the way on finger tight.
[Re: John_Kunkel]
#2669406
06/24/19 02:43 PM
06/24/19 02:43 PM
TJP
Omaha Ne
Chase the threads on the pin so the nut will go all the way on finger tight. The threads are fine, the pin begins too spin when one tries to tighten it. I was under the impression that the the pins were tapered as was the sleeve in the k frame for an interference fit as it is tightened ?
[Re: TJP]
#2669415
06/24/19 03:08 PM
06/24/19 03:08 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
When using those poly bushings, aren't you supposed to put the shaft, (pin) in first, tighten the nut down, by holding the shaft with vice grips, or channel lock pliers. Then installing the bushing in the LCA's onto the shaft?
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: TJP]
#2669419
06/24/19 03:24 PM
06/24/19 03:24 PM
Posts: 211 ILL
Greentween
ILL
Chase the threads on the pin so the nut will go all the way on finger tight. The threads are fine, the pin begins too spin when one tries to tighten it. I was under the impression that the the pins were tapered as was the sleeve in the k frame for an interference fit as it is tightened ? Yes the pins are supposed to lock in on the taper. It may still spin while tightening if you use poly bushings. With rubber bushings they wont. Some aftermarkets are made with wrong taper though.
[Re: TJP]
#2669482
06/24/19 06:16 PM
06/24/19 06:16 PM
Posts: 8,866 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
After reading several posts on other forums I ordered new shafts from PST. they are supposed t be about .005" larger. We''l see if they tighten up Thanks for the inputs Why don't they make the bushings .005" tighter ?!?! Oh, wait, they wouldn't be able to sell you the pins! What a scam!
[Re: Stanton]
#2669504
06/24/19 07:27 PM
06/24/19 07:27 PM
TJP
Omaha Ne
After reading several posts on other forums I ordered new shafts from PST. they are supposed t be about .005" larger. We''l see if they tighten up Thanks for the inputs Why don't they make the bushings .005" tighter ?!?! Oh, wait, they wouldn't be able to sell you the pins! What a scam! The bushings weren't the problem, The original tapered shaft that fits into the K member was the problem
[Re: njmopar]
#2669554
06/24/19 09:36 PM
06/24/19 09:36 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The bushings weren't the problem, The original tapered shaft that fits into the K member was the problem How do you figure that? They'd work just fine in a bushing that put enough pressure on them to hold them.
