Re: I need more power [Re: polyspheric] #2668537
06/21/19 10:01 PM
06/21/19 10:01 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Down under we are in the same boat, we are going 10.0/10.1 but definitely want to be in the 9.8's for our Drag Challenge which is like your Drag Week. Our plan is to take a bit off the heads and get comp up slightly to about 13-1 and change over to E85 with a dyno session.
1963 Plymouth Max Wedge
1971 Barracuda
Re: I need more power [Re: ozymaxwedge] #2668543
06/21/19 10:24 PM
06/21/19 10:24 PM
Washington
skrews Offline
skrews  Offline
Washington
I know you said you don't want to spray it, but a 50 shot plate kit would get my vote.
Re: I need more power [Re: NoFrills] #2668760
06/22/19 04:18 PM
06/22/19 04:18 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Originally Posted by NoFrills
I do have a 418 short deck r3 but its 13:1 and dont really want to buy race gas for the whole trip. The car is fairly lightened. No back seat or heater. Most of the brackets are gone or swiss cheesed. Usually run it with around 7 to 10 gallons of fuel. Would like to put a set of trickflow heads on it but am waiting on a coupon or Ebay sale.
Set of flat tops into that other short block, TF heads, bigger cam...... should be well into the 10’s.
Also, the pistons can be swapped, heads and cam installed into the other long block, then it’s a weekend motor swap and you’re ready to rock.
Opening day of DW will be here before you know it.
But I also agree that a small shot is the quickest and easiest path forward.
Re: I need more power [Re: fast68plymouth] #2668768
06/22/19 05:23 PM
06/22/19 05:23 PM
East Brunswick New Jersey
N
NoFrills Offline OP
NoFrills  Offline OP
N
Unfortionitly the 418 is 4.185 bore and the 374 is 4..080
Re: I need more power [Re: NoFrills] #2669047
06/23/19 02:56 PM
06/23/19 02:56 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
You already have the heads. I wouldn’t waste money on different ones. My vote is to try the heads, and have your current cam reground with another 15 degrees and more lift. A cam regrind is only 150 bucks.
The w2 is gonna work better than any aluminum head that doesn’t have a offset rocker. Even if the advertised flow is the same as the w2 the w2 will make more with the extra cross section.
Re: I need more power [Re: viperblue72] #2669132
06/23/19 08:18 PM
06/23/19 08:18 PM
So. Burlington, Vt.
So. Burlington, Vt.
Unless I missed something......... the current combo is running X heads.
Edit: I see where he “has” some w2’s.
Re: I need more power [Re: fast68plymouth] #2669155
06/23/19 09:42 PM
06/23/19 09:42 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I have worked at weight reduction without spending money and my car without me in it is still over 2900. When your running exhaust and have to fit drag week rules, you can't just start cutting everything out of the car.
And you cant put a 50 shot on a car running in the NA classes
To kill 2 birds with one stone would be a set of aluminum heads on the 418. Have the chambers opened up to fit the big bore and kill some Comp and unshroud the valves. I would opt for indy heads with bigger port than the trick flows although the TF's with a mild street friendly gear would work well
Re: I need more power [Re: sixpackgut] #2669344
06/24/19 12:43 PM
06/24/19 12:43 PM
N
NoFrills Offline OP
NoFrills  Offline OP
N
I think the plan of the minute is to put my w2s on the 374 with a old comp 20-730-9 that I have and try it. The new to it cam is 627 638 lift and 276 281 at 50.
Re: I need more power [Re: NoFrills] #2669346
06/24/19 12:46 PM
06/24/19 12:46 PM
So. Burlington, Vt.
So. Burlington, Vt.
It’s easy spending other people’s money........ but that’s def not the cam I would use.
Re: I need more power [Re: thecarfarmer] #2669440
06/24/19 04:10 PM
06/24/19 04:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was thinking(I know..its hard) just put the 13:1 engine back in (as is) and
pull some timing and put a good meth kit on it.. simple.. you dont care how
quick it is on the street but you will have the torque you will need with the
416
wave
