b body small block radiator #2668984
06/23/19 10:37 AM
06/23/19 10:37 AM
Kemblesville, PA
dart14 Offline OP
dart14  Offline OP
Kemblesville, PA
does anybody make a replacement for a 1969 b body small block radiator (Coronet 500 318)? PN 2949060. Automatic. The core measures approx 18" high x 18 3/4" wide. Inlet & Outlet both measure 1 1/2" on the left side. No shroud. If not. is there a 22" wide that would bolt right in and look original with the trans lines attaching with no modifications ?
Re: b body small block radiator [Re: dart14] #2669093
06/23/19 05:30 PM
06/23/19 05:30 PM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
Autocity1958 is the e-bay ID/name. I bought a rad from them for my 69 Coronet SB this spring. it was very nice! alm. not an OE but looks very close. can post pics if you wish.
HEMI,S ARE FOREVER!!!
Re: b body small block radiator [Re: dart14] #2669249
06/24/19 08:02 AM
06/24/19 08:02 AM
Wausau,Wisconsin
Kilrbee Offline
Kilrbee  Offline
Wausau,Wisconsin
Glen-Ray can get you set up with what you are looking for... callme
