ATI damper for RB with Indy timing cover
#2668836
06/22/19 09:24 PM
06/22/19 09:24 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Anybody positive which ATI super damper i would need with the Indy cast timing cover with crank hub spacer? I thought it was the same one as for the jesel belt drive setup, but i want to make sure before i pull the trigger. Figured i’d check here with the experts first instead of calling and possibly waiting on hold.
Re: ATI damper for RB with Indy timing cover
[Re: cudatom]
#2668879
06/22/19 11:28 PM
06/22/19 11:28 PM
Chargerfan68
New York, USA
ATI #917127E damper is the one I have. Thanks for the info
[Re: Chargerfan68]
#2669161
06/23/19 09:58 PM
06/23/19 09:58 PM
Posts: 89 Cedar Rapids, IA
69Mcode440
Cedar Rapids, IA
They have a chart on their website with the info you need.
Mike
Mike 69 440 Cuda 71 Dart drag car 70 Duster drag car Best et 9.32, 145.9 mph 2019 Ram 2500 4x4
[Re: 69Mcode440]
#2669181
06/23/19 10:35 PM
06/23/19 10:35 PM
Chargerfan68
New York, USA
Mike Yes, thanks. I did find that chart, but like in the past, i have purchased parts from company websites, and they did not fit right, or were incorrectly listed. I figured its best to ask the real deal racers here that built this combo. Thanks for pointing that out though.
[Re: Chargerfan68]
#2669183
06/23/19 10:43 PM
06/23/19 10:43 PM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I had to put a small shim that ATI offers behind my ATI damper with my Indy cover.
[Re: Chargerfan68]
#2669615
06/24/19 11:31 PM
06/24/19 11:31 PM
69Mcode440
Cedar Rapids, IA
I bought the hub listed for use with the indy cover and just swapped it with the original hub on my ATI damper. Summit has them in stock.
Mike
