Cam for 505 stroker #2668362
06/21/19 01:17 PM
06/21/19 01:17 PM
Norway
General 68 Offline OP
Norway
Looking for a street friendly hydraulic flat tappet Cam for a 440/512 stroker.
CR 9,8:1, Stage 4 iron heads, 1,6 rockers, Indy dual plane intake, 2" headers, 3" x-pipe.
Manual trans
Want lots of low end torque and vacuumn for power brakes.
Heavy car, 4200lb, mostly street driven.
Any experience with Hughes Engines cams? Looking at the SEH2832BL-10 or
SEH3236BL-10 or Are they too much?
Re: Cam for 505 stroker [Re: General 68] #2668378
06/21/19 02:00 PM
06/21/19 02:00 PM
AndyF Offline
AndyF  Offline
It all depends what street friendly means to you. I had a 246/246 hyd roller in the 512 inch stroker in my Coronet and I decided it was a little too big for the type of driving that I was doing. It worked great on the freeway but was just a little too rumpy around town. My new engine has a 239/245 hyd roller in it and it seems to be a better fit. Either of the cams you posted should work okay for what you're describing. They are fairly small and will kill off a bunch of power up top, but they should give you a fairly smooth idle and plenty of torque down low. Your headers are too big for what you are doing but you might not be able to change them at this point. For bottom end torque you probably don't need anything larger than 1 3/4 inch header.
Re: Cam for 505 stroker [Re: AndyF] #2668435
06/21/19 04:57 PM
06/21/19 04:57 PM
Norway
Norway
Thanks! I might try the bigger one of them - 232/236. Afraid og going too big. Street friendly to me is to be able to cruise in 5th gear at 17-1800 rpm at 50 mph, go through town i stå and go traffic without lugging and still be able to fru the tires from a roll ion 2th gear. Also want vacuumn for power brakes. Will this combo do all this?😀
Re: Cam for 505 stroker [Re: General 68] #2668454
06/21/19 05:34 PM
06/21/19 05:34 PM
AndyF Offline
AndyF  Offline
Cruising at 1800 rpm in 5th gear requires an engine to be tuned for a fairly low torque peak. Your engine with the Indy intake and the 2 inch headers is tuned to run really efficient at 4000 or higher. A smaller cam will help but if you want decent gas mileage at 1800 rpm you'll most likely need to swap in a Performer RPM intake and maybe try some smaller headers.
Re: Cam for 505 stroker [Re: AndyF] #2668460
06/21/19 05:49 PM
06/21/19 05:49 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I bought the 470" short block "dyno mule" AndyF built. It "came" with a largish mechanical cam. I installed max ported Edelbrock RPM heads and a single plane intake. The engine wouldn't even turn on till 2000rpm (have a manual trans). almost like the accelerator was an on/off switch. Absolutely no fun to drive. So I put on the RPM dual plane intake Andy mentions above and the smallest old skool Mopar "Purple Shaft" mechanical cam (284/284, Lift .528/.528) and now its a torque beast. I can boil the 295s. Its fun to drive. Lopey but drives like an angry grocery getter smile
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Cam for 505 stroker [Re: AndyF] #2668467
06/21/19 06:00 PM
06/21/19 06:00 PM
Norway
Norway
Yupp, I know. But for now this is the parts I have and the .484 purple shaft in it is not speaking the same landguage as power brakes so I am trying to get the best out of the existing parts. Ran the 2" headers on a mild 440 with Torker 2 intake and a Lunati Voodoo 226/234-10 without any issues so I hope the 512 with a relatively mild cam will be just as strong
Re: Cam for 505 stroker [Re: General 68] #2668570
06/21/19 11:41 PM
06/21/19 11:41 PM
s. e. pa.
calrobb2000 Online content
calrobb2000  Online Content
s. e. pa.
hi
anther vote for the 284 / 528 solid .
Re: Cam for 505 stroker [Re: General 68] #2668607
06/22/19 08:31 AM
06/22/19 08:31 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
No one seems to talk about cam overlap anymore. The smart cam people will correctly tell you that the overlap is nothing more than the outcome of picking the right cam opening and closing events. But I believe that it still has a place for us amateurs that are trying to pick a compromise cam, which is exactly what a max. power with a good idle cam is. So with that, consider a cam with a 112° lsa, and an overlap of no more than about 60°.
My cam has over 240° @ 0.050" and 54° overlap. Idles with 13" vacuum in gear at 750 rpm. It drives in 3 rd gear at 1100 rpm. It has the Indy 2D.
2" headers do seem a bit much, but then again, I don't know much about big tube headers.
Re: Cam for 505 stroker [Re: BSB67] #2668701
06/22/19 12:49 PM
06/22/19 12:49 PM
Norway
Norway
Thanks BSB67
Cam you describe more of your engine an how it performs?
Re: Cam for 505 stroker [Re: General 68] #2669761
06/25/19 12:06 PM
06/25/19 12:06 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
Id go with the 509 its pretty mild in a 440
Re: Cam for 505 stroker [Re: moparsquid] #2669882
06/25/19 06:41 PM
06/25/19 06:41 PM
houston, mo
johnnmo Offline
johnnmo  Offline
houston, mo
I've used the solid 284 cam too for a 498. It was strong for a street cam.
Re: Cam for 505 stroker [Re: General 68] #2669986
06/25/19 10:28 PM
06/25/19 10:28 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Dwayne spec'd custom cam for manifolds. Runs 11s in decent air. Street tires and crap 60 ft times.
http://508charger.yolasite.com/
Re: Cam for 505 stroker [Re: General 68] #2670221
06/26/19 02:01 PM
06/26/19 02:01 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'm running the 23-712-9 Comp Cams Hydraulic roller cam, XR286HR10 in my 505 engine. It is 236/242 duration @ 0.050 and drives fine doing 50 MPH @ 1,500 RPM in 5th gear (Legend Gear & Transmission 700 transmission.)
Engine is about 10.3:1 compression, Mild ported stealth heads, 17cc dished pistons, 1-7/8" TTI headers with 2.5" dual exhaust with X-Pipe. Originally a Performer RPM intake, but now Edelbrock XT EFI intake and FAST 2.0 EFI controller.
Re: Cam for 505 stroker [Re: 451Mopar] #2670282
06/26/19 04:04 PM
06/26/19 04:04 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
This is the Hyd roller 1.6 rockers I have in my 512 Charger, 3.54 gear Overdrive trans with lock up converter, I can cruise at 1800 rpm smooth with no bucking. power brake friendly?? NO
Re: Cam for 505 stroker [Re: CSK] #2670345
06/26/19 06:49 PM
06/26/19 06:49 PM
Norway
Norway
Thanks! Keep it coming😄
I just ordered the 232/236-110 Hughes cam. Quite exited to ser how it performs.
This is a mild build, 505,cr 9,8:1, Stage 4 iron heads, Indy dual plane, 2" tti's, 3" x-pipe, Holley 850 dp.
4200 lb '68 Charger, Tko 600 5-speed, Dana/Moser 60.
I have an opinion on how it will perform, but what are your opinion?
Re: Cam for 505 stroker [Re: General 68] #2670362
06/26/19 07:26 PM
06/26/19 07:26 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
It will be a handful on the street, small cam for a 512
Re: Cam for 505 stroker [Re: General 68] #2670757
06/27/19 03:42 PM
06/27/19 03:42 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I've been running a Hughes HE3844BL in a street-strip 400/470 E-Body, 4 spd. for 15 years. Here's the link to the cam's profile (http://www.hughesengines.com/TechArticles/heseriescamprofilesbigblockhydraulic.php) if you like to compare with the Hughes cams you're considering. My motor has slightly more compression, E-heads, 1.6 rockers, Performer Plus intake, 1-7/8 headers with 3" exhaust, 4:10 or 3:55 gears, 3600 lbs. w/o driver, manual brakes. Low end torque is outstanding. I can lug the motor down and she pulls strong and easily to 6k.
At the time, Hughes spec out the 3844 and the HE4449BL since I wanted to go with a hyd. flat tappet. With the added cubes you have, I believe you will be more than happy with the 3236.
Re: Cam for 505 stroker [Re: General 68] #2670781
06/27/19 04:44 PM
06/27/19 04:44 PM
AndyF Offline
AndyF  Offline
It should have a fairly smooth idle and a ton of torque down low. It will most likely run out of air by 5500 rpm but you'll be going so fast at that point that you won't care. A street car doesn't need a race cam even though a lot of people want to put race cams in street cars.
Re: Cam for 505 stroker [Re: AndyF] #2683789
08/02/19 06:19 PM
08/02/19 06:19 PM
Norway
Norway
Well guys, I got the answers now🤣
Got the engine together and put in the Charger just in time to reach Orsa Dragfest in Sweden.
Broke in the cam the night before we went and everything was good.
Went 8.23/88.5 in the 1/8 mile. 4300lbs with med in. No prep track, Hoosier Quicktime Pro's, 28/12..5/15. Manual trans.
Good vacuumn for power brakes. Engine pulled super strong. No change hooking - actually blew the tires loose when dropping the clutch at 2000 rpm. Quite scary - easy to over rew as it would fly past 6000 rpm in no time. Never got the 60' under 1,88 seconds.
Broke the tires loose a bit when shifting to 2. gear. Pulled strong all the way to 6k.
Won the bracket race (Had some luck😄) Idles nice and smooth at 1000 rpm.
I only got time for a short test drive on travel road. Touching the go- pedal at 2000 rpm in 3rd gear would send the car sideways down the road. So far I am happy with the combo, but some carb- and chassis tuning might take it to the next level.
Re: Cam for 505 stroker [Re: General 68] #2921317
05/11/21 07:09 PM
05/11/21 07:09 PM
NY
B1duster Offline
B1duster  Offline
NY
What octane fuel do you use ?
