Page 3 of 3 1 2 3
Re: Foot braking with Caltracs and preload? [Re: moparniac] #1249043
06/15/12 03:55 PM
06/15/12 03:55 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
All this discussion has got me thinking about my setup. I have Cal-tracs with mono leaf springs, bottom hole, ¾ turn pre load on right and about ¼ on left. Best 60 on a good track 1.403. On an average track is 1.44 to 1.46. Poor track it spins. I going out to move the bar to top hole for tonight’s T&T just to see what the top hole will do. The track usually is average to poor on Friday night. My car weighs 2840 with me and 8 gallons of fuel in it.
Re: Foot braking with Caltracs and preload? [Re: clovis] #2668365
06/21/19 01:20 PM
06/21/19 01:20 PM
Menomonie,wi
menomoniemopars Offline
Menomonie,wi
Originally Posted by clovis
I have just finished doing some experimenting with preload on the Duster. Our first passes was with .085 (we used an old brake adjuster feeler gauge) of clearance between the spring and pin, with me in the car. With the air gap the car would pick up the front end. When we set the pin on the spring with me in it, it would not pick up up the front end and the rear body separation during staging was very pronounced. I was trying to bring it out at about 3,300 rpms. The 60ft is a tad better with the gap. It left me with the impression that there is a difference in pressure and hit. The pressure on the tire is greater with the preload, but there seems to be a bigger "hit" with the gap.
We then swapped out the old six cylinder springs for the Caltrac monos and went to the top hole and a gap. This gave us the lowest and most consistent 60ft we have had with the car and this was leaving at 1,700 rpm. I wanted to see if letting the converter swing a bit would hurt or help. Next time out we will try coming out about 3,500-4,000 (whatever the brakes will hold) and see what that does to the 60 ft. In the past the higher launch rpm has created a better 60ft. I think it also has a lot to do with getting the motor in its happy place. With the 590 cam I think the 3,500 mark is a more preferable spot than 1,700. I try to get my videos posted so you can see, but for the time being, here is one of last passes with the monos.
Sent ya a pm
Re: Foot braking with Caltracs and preload? [Re: menomoniemopars] #2668477
06/21/19 06:24 PM
06/21/19 06:24 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Bottom hole no preload. Nickel gap dr side and just touching on rt side. Leave just off idle.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Page 3 of 3 1 2 3
