Re: I need more power
[Re: polyspheric]
#2668537
06/21/19 10:01 PM
06/21/19 10:01 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Down under we are in the same boat, we are going 10.0/10.1 but definitely want to be in the 9.8's for our Drag Challenge which is like your Drag Week. Our plan is to take a bit off the heads and get comp up slightly to about 13-1 and change over to E85 with a dyno session.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: NoFrills]
#2668760
06/22/19 04:18 PM
06/22/19 04:18 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I do have a 418 short deck r3 but its 13:1 and dont really want to buy race gas for the whole trip. The car is fairly lightened. No back seat or heater. Most of the brackets are gone or swiss cheesed. Usually run it with around 7 to 10 gallons of fuel. Would like to put a set of trickflow heads on it but am waiting on a coupon or Ebay sale. Set of flat tops into that other short block, TF heads, bigger cam...... should be well into the 10’s. Also, the pistons can be swapped, heads and cam installed into the other long block, then it’s a weekend motor swap and you’re ready to rock. Opening day of DW will be here before you know it. But I also agree that a small shot is the quickest and easiest path forward.
[Re: viperblue72]
#2669132
06/23/19 08:18 PM
06/23/19 08:18 PM
fast68plymouth
So. Burlington, Vt.
Unless I missed something......... the current combo is running X heads.
Edit: I see where he “has” some w2’s.
[Re: fast68plymouth]
#2669155
06/23/19 09:42 PM
06/23/19 09:42 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I have worked at weight reduction without spending money and my car without me in it is still over 2900. When your running exhaust and have to fit drag week rules, you can't just start cutting everything out of the car.
And you cant put a 50 shot on a car running in the NA classes
To kill 2 birds with one stone would be a set of aluminum heads on the 418. Have the chambers opened up to fit the big bore and kill some Comp and unshroud the valves. I would opt for indy heads with bigger port than the trick flows although the TF's with a mild street friendly gear would work well
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: NoFrills]
#2669346
06/24/19 12:46 PM
06/24/19 12:46 PM
fast68plymouth
So. Burlington, Vt.
It’s easy spending other people’s money........ but that’s def not the cam I would use.
[Re: thecarfarmer]
#2669440
06/24/19 04:10 PM
06/24/19 04:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I was thinking(I know..its hard) just put the 13:1 engine back in (as is) and pull some timing and put a good meth kit on it.. simple.. you dont care how quick it is on the street but you will have the torque you will need with the 416
