Which oil to use? Solid Roller #2666131
06/15/19 09:38 AM
06/15/19 09:38 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Here are some specs
500 in wedge
Comp Solid Roller cam
Procharger set up
around 800 hp.
I am currently using Brad Penn 20-50
It is difficult to find and expensive.
Are the are good options?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Which oil to use? Solid Roller [Re: Kam*Kuda] #2666171
06/15/19 11:54 AM
06/15/19 11:54 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Valvoline VR1 Racing 20w50 is what I always run. Zinc level is around 1200ppm when I test it. Just bought 2 cases on sale from Napa for $4.80 a Qt.
The only Carbs I care about are under the hood!
Re: Which oil to use? Solid Roller [Re: Kam*Kuda] #2666173
06/15/19 11:58 AM
06/15/19 11:58 AM
On your deal, especially if you drive it when the outside air temps are below 50F, I would use either 5W20WT, 5W30Wt or 10W30 WT.
As far as which brand I like and use Valvoline oil based non synthetics oils, maybe VR1 with higher valve spring pressure for solid roller cams up
Re: Which oil to use? Solid Roller [Re: Kam*Kuda] #2666266
06/15/19 06:30 PM
06/15/19 06:30 PM
AndyF Offline
AndyF  Offline
I doubt that it matters much. Pick a viscosity to match your bearing clearances and pay attention to the oil temp. If the oil temp gets hot then you might want to run a synthetic. Otherwise any name brand oil will work.
Re: Which oil to use? Solid Roller [Re: Kam*Kuda] #2666295
06/15/19 07:43 PM
06/15/19 07:43 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The "20" part takes longer to reach the farthest bearing. Drop to 5W or 10W-50.
My recent experience: factory calls for 10W30 (Toyota factory turbo engine), gets used in cools temps and 250 hp over the original engine, last change used 5W40.
Feels the same, except... the hot idle speed is down slightly - takes extra power to churn through that 40.
Boffin Emeritus
Re: Which oil to use? Solid Roller [Re: polyspheric] #2666333
06/15/19 10:14 PM
06/15/19 10:14 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Ok, not all of Canada is above the Arctic circle - in fact, a large portion of the Canadian population lives further south than you Cab !!
Re: Which oil to use? Solid Roller [Re: Stanton] #2666381
06/16/19 06:39 AM
06/16/19 06:39 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Nu-Gold is the right stuff for you but I always ran rotella
Re: Which oil to use? Solid Roller [Re: Stanton] #2666562
06/16/19 04:01 PM
06/16/19 04:01 PM
Originally Posted by Stanton
Quote
The last time I look at a good globe the only part of Canada that is further south than central Oregon is near Detroit work
Is that one of the densest population centers in Canada confused
Isn't Toronto and Quebec further north than Bend, OR?
Re: Which oil to use? Solid Roller [Re: Kam*Kuda] #2666628
06/16/19 07:32 PM
06/16/19 07:32 PM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
MOBIL 1 0w40 for that would be great.
Re: Which oil to use? Solid Roller [Re: Kam*Kuda] #2666692
06/16/19 10:36 PM
06/16/19 10:36 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Is Driven oil available to you?
IMO, an 800 HP engine isn't something that I'd want to cheap out on the oil.
Re: Which oil to use? Solid Roller [Re: BradH] #2666770
06/17/19 09:42 AM
06/17/19 09:42 AM
an8sec70cuda Offline
Valvoline VR1
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Which oil to use? Solid Roller [Re: an8sec70cuda] #2666815
06/17/19 10:56 AM
06/17/19 10:56 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Originally Posted by an8sec70cuda
Valvoline VR1
I heard good things about VR1
I had read about 10-50 vs 0-50 The 10-50 weight maybe better due to the modifiers.
https://www.bobistheoilguy.com/motor-oil-103/
1654.5 Mustang
1955 Land Rover
Re: Which oil to use? Solid Roller [Re: pro451bee] #2667556
06/19/19 12:29 PM
06/19/19 12:29 PM
Minnesota, USA
minnesota guy Offline
Minnesota, USA
This is very good oil. It has a high PSI lubrication ability. Check out over 200 oils ranked by PSI --by 540 RAT GUY. He has a blog to ask questions and has ranking of all the popular oils put to his test. Amzoil 5w-30 Signature series is his highest ever ranking oil ever..But M-1 0w-40 Full Synthetic is right behind it. He runs 800 HP motors and his oil of choice is QS 5w-30 FS because it holds it values at higher temps. Anyway, good read and take it for what you get out of it.
Re: Which oil to use? Solid Roller [Re: minnesota guy] #2667564
06/19/19 12:39 PM
06/19/19 12:39 PM
Washington
madscientist Offline
Washington
That guy is a joke. His testing is a joke. His results are a joke.
Re: Which oil to use? Solid Roller [Re: Kam*Kuda] #2667576
06/19/19 01:01 PM
06/19/19 01:01 PM
NC
440Jim Offline
440Jim  Offline
NC
I have used Brad Penn (now Penn Grade 1) for many years.
The 20W-50 is in my street/strip car since the oil gets hot driving on the street.
I have been using 10W-30 in my drag race cars for years. A local supplier sells a case of 12 for $75.
IMO, Mobil VR-1 is just fine.
Re: Which oil to use? Solid Roller [Re: an8sec70cuda] #2667582
06/19/19 01:14 PM
06/19/19 01:14 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Valvoline VR1
Facts are stubborn things.
Re: Which oil to use? Solid Roller [Re: larrymopar360] #2667611
06/19/19 02:30 PM
06/19/19 02:30 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Rich H.
Esse Quam Videri
Re: Which oil to use? Solid Roller [Re: ZIPPY] #2667613
06/19/19 02:35 PM
06/19/19 02:35 PM
The Mobil One 15w50 synthetic I used to use got hard to find for a while, so I went w/ the VR1.
CHIP
Re: Which oil to use? Solid Roller [Re: larrymopar360] #2667727
06/19/19 08:28 PM
06/19/19 08:28 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Valvoline VR1
since Brad Penn has become harder to get around here I have changed to Valvoline VR-1 and get it at Rural King for 4.99 a quart.
