Re: Air Cleaner Lid---what does it fit?
[Re: horsepower.2007]
#2666541
06/16/19 02:02 PM
06/16/19 02:02 PM
Posts: 16,425 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
That would also fit later 318 four barrel cars such as '82 thru '89 Diplomat/Gran Fury AHB's (such as my '89 Diplomat pictured), and the E58 360's.
Facts are stubborn things.
#2666614
06/16/19 05:50 PM
06/16/19 05:50 PM
Posts: 4,807 Ontario, Canada
mccannix
Ontario, Canada
...as common as a belly button.. Should fit any 1970 - 74 340 - 360 - 383 - 400 - 440 dual or single snorkel 2 and 4 barrel cars. HP ones were painted orange. ....HP ones only painted orange starting in 1972..
[Re: Powerflow]
#2666640
06/16/19 06:58 PM
06/16/19 06:58 PM
Posts: 16,997 Between Houston & Galveston TX
SattyNoCar
This space for rent
This space for rent
Thanks for the quick replies. Surprising that it fits so many cars. Not really. Chrysler shared a LOT of parts over various models over various years. It would have cost too much $$$$ to have individual parts for EVERY model for EVERY make. I used the dash controls for the heat/ac from a '77 Fury (B-body) in a '84 Dodge PU for example. The ONLY difference were the buttons. The B-body pice had black buttons, the truck had chrome buttons. How it bolted in and all other attachments were EXACTLY the same. This is also why so many 'sellers' attach keywords like 440-6 or HEMI to parts because they know it'll fetch more even though the same part came on Granny's slant 6 Coronet.
John
[Re: 70X]
#2667483
06/19/19 08:35 AM
06/19/19 08:35 AM
Posts: 7,395 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
The lids that take a pie tin are shaped differently in the area around the wing nut.
I have an air cleaner from my old 76 Charger SE.(360 2-barrel) I also have an air cleaner from a 76 Newport.(400 4-barrel lean burn) The 400 lid was bent so I was going to swap it out with the 360 lid.(they are the same diameter) The "lean burn" pie tin does not fit on the 360 lid. It doesn't sit down flush because of how the wing nut area is shaped.
[Re: burdar]
#2667539
06/19/19 11:07 AM
06/19/19 11:07 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
On my 360 AHB with that lid, I've had this pie tin (the 360-4 one) and it fit perfect, but then switched to this sticker as I kind of prefer it now. It's more stock appearing.
