Looking for GOOD head porter
#2667324
06/18/19 06:50 PM
06/18/19 06:50 PM
Posts: 201 Texas
Chief
Texas
I have a set of 440-1 heads that I would like to get brought into 21st century. Heads were originally ported/flowed by Muscle Motors in 2001, I am attaching the flow sheet. I had to practically beg them over a 2 month time frame to send me the flow sheet. I have always had doubts that it is really the flow sheet for my heads, and not just one they pulled out of their files and sent me to get me off their back. I have called and emailed Modern Cyl Heads, and Chad Speier but I guess they do not need any more business as they never returned my call or emails. Heads are on my 500 cu. in. 8.71 blown/injected, on alcohol, dragster. So I am looking for a good head guy. Thanks Dave
Dave Covey
Re: Looking for GOOD head porter
[Re: Chief]
#2667335
06/18/19 07:15 PM
06/18/19 07:15 PM
Posts: 314 Medina, OH
dart440_72
Medina, OH
Nick Jr. at Compuflow did mine. I'm really happy with them.
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
[Re: DavidDean]
#2667339
06/18/19 07:29 PM
06/18/19 07:29 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
Dwayne Porter member here, fast68plymouth
[Re: dart440_72]
#2667340
06/18/19 07:32 PM
06/18/19 07:32 PM
Posts: 10,560 Rittman Ohio
fourgearsavoy
Rittman Ohio
Nick Jr. at Compuflow did mine. I'm really happy with them. Jr. is a very bright young man and he really paid attention when his father taught him how to port heads and build engines. If he is too busy Bart Anderson is very good too and he also learned some tips from Nick to make Indy heads flow nice. If you wan't more info send me a PM so I can get your info to either of these gentlemen. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: CSK]
#2667341
06/18/19 07:34 PM
06/18/19 07:34 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Dwayne Porter member here, fast68plymouth X2 And I'm sure you should get detailed before and after reports that are for YOUR heads.
[Re: Chief]
#2667345
06/18/19 07:57 PM
06/18/19 07:57 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Give some consideration into stepping up to a 2.250 intake valve when you send them out. I ported the set I am putting on a 505 and they are flowing great but I want to see how close to 400 cfm I can get them to. The 440-1 heads get a weight break as the B1 heads do not so I’m curious how far I can get them.
[Re: AndyF]
#2667370
06/18/19 08:43 PM
06/18/19 08:43 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
If they were my heads they would be on the way to Porter Racing Heads in VT. If that is too far away from you then you might consider IMM in Indio, CA or Fastlane Machine in Utah. If he has to put them in a box and ship,PORTER might be $40 more in shipping,,,or less they are aluminum Define too far..........
[Re: wyoming]
#2667378
06/18/19 09:03 PM
06/18/19 09:03 PM
Posts: 326 Alberta
Wookie316
Alberta
Dwayne did my 440-1’s. Excellent job. Wouldn’t hesitate to recommend him. My EZ-1’s were done by Nick Sr. Did not know his son took over after he passed away. That’s good to hear that the family business is still going.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: Wookie316]
#2667416
06/19/19 12:47 AM
06/19/19 12:47 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Porter would be my choice.
The Goodwin raised port indy heads sold by Best Machine would be something I would want if my wallet would allow
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2667418
06/19/19 01:02 AM
06/19/19 01:02 AM
Posts: 422 montana
BANDIT
montana
Dwayne is the man, very knowledgeable and easy to deal with. Won’t blow smoke up your dress either. Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: BANDIT]
#2667424
06/19/19 02:39 AM
06/19/19 02:39 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
Dwayne told me years ago to send my Eddy RPM to Modern for CNC porting, that was before Jeff passed away I had him do several CNC porting on some B1-BS and some other 440-1 , all ran good on the motors Bob has told me several years ago that he is very busy now and the normal porting delivery time is about 3 to 4 months out after he receives them I tried a local roundy round race machine shop in Vancouver, WA last year on one of my own street motors and ended up being very disappointed on a set of 440-1 that I wanted them to replace the valve guides and anything else they needed, they came back with the guides way looser than I like or expected They had done some other street motor head work for me in the past that was good, not anymore now My message is go for the best you can get when it comes to head work, just like brain surgery
[Re: Cab_Burge]
#2667490
06/19/19 09:57 AM
06/19/19 09:57 AM
hemi-itis
Yes,there are several porters around,I feel that the porting procedure is only part of the picture! Dwayne will not only port and flow your heads,but help you with the entire package.Match a cam and the right springs to your heads,better off letting him assemble the head !!!
[Re: pittsburghracer]
#2667499
06/19/19 10:30 AM
06/19/19 10:30 AM
Posts: 201 Texas
Chief
Texas
Give some consideration into stepping up to a 2.250 intake valve when you send them out. I ported the set I am putting on a 505 and they are flowing great but I want to see how close to 400 cfm I can get them to. The 440-1 heads get a weight break as the B1 heads do not so I’m curious how far I can get them. I have already decided to go there. Valves in hand.. Dave
Dave Covey
[Re: Chief]
#2667531
06/19/19 11:53 AM
06/19/19 11:53 AM
Posts: 201 Texas
Chief
Texas
Thanks for the recommendations guy's.
I spoke with Dwayne and had a good talk about my issues. It seems it would be a waste to mess with these heads so he saved me some money on these..lol
Good guy to talk to. I'll send out my next set of heads to him.
Dave Covey
[Re: Chief]
#2667551
06/19/19 12:28 PM
06/19/19 12:28 PM
Posts: 19,398 Las Vegas
Al_Alguire
Las Vegas
Lots of cylinder head guys out there. If you want hands down the BEST then I would talk to Tom Slawko at Slawko racing heads. Self Racing Heads is another very good shop. The aforementioned shops I am sure also do very good work. Dwayne is always highly spoken of, and I have had some stuff done by CompuFlo and it was nice.
[Re: BANDIT]
#2667596
06/19/19 01:48 PM
06/19/19 01:48 PM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
Dwayne is the man, very knowledgeable and easy to deal with. Won’t blow smoke up your dress either. Jim. Dwayne Porter FTW
[Re: an8sec70cuda]
#2667627
06/19/19 03:19 PM
06/19/19 03:19 PM
Posts: 1,265 New York, USA
Chargerfan68
New York, USA
Dwayne Porter! Superb porting, always willing to discuss engine builds and devotes his time, and his word is GOLDEN , in my experiences. Mine would be off to him
[Re: Chief]
#2667863
06/20/19 08:53 AM
06/20/19 08:53 AM
BradH
We're you looking for improvements beyond what he considers cost effective for those heads?
[Re: FurryStump]
#2667896
06/20/19 10:17 AM
06/20/19 10:17 AM
hemi-itis
How many vendors still come om here and POST. Jump in on conversation and give UNsolicited advise. Not too many left!!
[Re: racerhog]
#2668211
06/21/19 01:55 AM
06/21/19 01:55 AM
Cab_Burge
Shane and his Dad specialized in NHRA stokers and SS, not all out street motors usually I used Don on some of my iron heads for street and strip a long time ago, several years before he moved to Utah and passed away Al Etter moved 1/2 a block down the street from me in Hesperia before we moved up here to Oregon My how time has flown
[Re: Cab_Burge]
#2668283
06/21/19 10:27 AM
06/21/19 10:27 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Dwayne Porter for sure. I’ve been using him for over 15 years and very happy with everything he’s done for me. He does fantastic port work, but also extremely informative, honest, quick and fair.
2 kids and a dog
