47RH Transmission in 2005 Ram Cummins #2667005
06/17/19 08:41 PM
06/17/19 08:41 PM
Central New York
bfury Offline OP
bfury  Offline OP
Central New York
Does this trans use the same bands as a 727?
No Stock
Re: 47RH Transmission in 2005 Ram Cummins [Re: bfury] #2667055
06/17/19 11:08 PM
06/17/19 11:08 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Front one yes, rear one no.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: 47RH Transmission in 2005 Ram Cummins [Re: Prodart440] #2667110
06/18/19 08:38 AM
06/18/19 08:38 AM
houston, mo
johnnmo Offline
johnnmo  Offline
houston, mo
Also, you should know that the trans in the 96 and newer is a 47RE. The front band is a good band but the apply lever and strut are weak IF you add a lot of pressure.
On edit, after 03 it is a 48RE!!!
Re: 47RH Transmission in 2005 Ram Cummins [Re: johnnmo] #2667460
06/19/19 08:35 AM
06/19/19 08:35 AM
crlush Offline
crlush  Offline
Did you install a 47rh for some reason, if its stock it should have a 48re.
