Re: 69 park lamp pigtail removal
[Re: roadrunninMark]
#2666878
06/17/19 12:49 PM
06/17/19 12:49 PM
RapidRobert
I would imagine that you would need to crimp the socket inward till it is free to come out the front of the housing & maybe do some dremeling
#2666957
06/17/19 04:49 PM
06/17/19 04:49 PM
Posts: 784 Florida
cbusters
On my 69 RR, my one park lamp (bumper mounted) has a rusted out bulb socket. The housing is fine, I am looking to change out the socket-pigtail. I bought another housing/pigtail from an a body and want to swap the good one into mine. Has anyone tried this and know the proper way without messing up either the housing or the pigtail/socket? It appears to be crimped in on the inside of the housing; where the bulb goes.
Just trying to get some good advice from someone who has done this before I attempt it. The B body housings are not reproduced and are hard to find, so I am trying this way first. Pics of what I got and then the new one that is on the way:
Thanks, Mark I cut the old socket off with a cutoff wheel and worked the little pieces until the socket pieces came out of the housing. I cut the rear of the donor housing off and sliced the housing parts until they wiggled off the socket. I had one split on the socket flange and "screwed" it into the good housing like a screw. I slid the pig tail into a piece of conduit and used the tapered 1/2 drive sockets like punches to roll the crimped part back flat and then a kingpin that I had from a past project to flatten out the "ring" and get good contact for current.
[Re: HEMICUDA]
#2667081
06/18/19 03:45 AM
06/18/19 03:45 AM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
Send me your old ones, for $35, I'll press new ones in both. Man, if it were me, this is what I would do.
Scott
1969 Super Bee, 383/4 speed
[Re: HEMICUDA]
#2667088
06/18/19 06:13 AM
06/18/19 06:13 AM
Posts: 4,740 Florida
BDW
Send me your old ones, for $35, I'll press new ones in both. Do this! Mike replaced my Challenger pigtails, there was no way I could got this done myself, and the work was flawless. Thx again Mike, you’re truly an asset to the hobby.
[Re: HEMICUDA]
#2667173
06/18/19 12:16 PM
06/18/19 12:16 PM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
Mike, that is really good to know you can do this!!
-Eric
