19.5 rims #2665200
06/12/19 03:54 PM
06/12/19 03:54 PM
Iowa
coronetville Offline OP
Iowa
will 19.5 tires and rims fit my 1997 Dually [dodge] 4x4 ? clearance ,ok?
Re: 19.5 rims [Re: coronetville] #2665208
06/12/19 04:24 PM
06/12/19 04:24 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Originally Posted by coronetville
will 19.5 tires and rims fit my 1997 Dually [dodge] 4x4 ? clearance ,ok?/
They'll work, with adapters. Don't go anymore than 6.75" wide wheels. 7.5" stick out too far.
From experience, this is a modification I wouldn't repeat. 2ยข
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 19.5 rims [Re: 3hundred] #2666090
06/15/19 07:09 AM
06/15/19 07:09 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Not to mention the cost of 19.5 tires, unless you already have good ones on rims.
Re: 19.5 rims [Re: redraptor] #2666169
06/15/19 11:26 AM
06/15/19 11:26 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
My son runs them. He gets his tires cheaper than pickup tires.He works at a Kenworth dealer though and I think he buys takeoffs or something.
Sheldon
Re: 19.5 rims [Re: coronetville] #2668485
06/21/19 07:00 PM
06/21/19 07:00 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
I ran them on my '99 3500 4x4 with no problems at all. Found GM p-van wheels with the right bolt circle and had the centers opened up to match the Dodge hubs, no adapters needed. 19.5 rubber was cheap: find a tire dealer that services bus companies, they'll be able to get you steer tires recapped to whatever tread pattern you want (bus steer tires are THE ONLY place it's illegal to run a recap). With 4.10 gears and the Cummins, I picked up about 2 mpg with the 19.5's. Due to the stiff sidewall, I was running the rears with just enough air to keep the beads seated unless I was hauling a load. The look is MUCH better as it fills up that HUGE front wheel opening.
Re: 19.5 rims [Re: coronetville] #2669949
06/25/19 09:10 PM
06/25/19 09:10 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
They fit on my 98 dually....
Re: 19.5 rims [Re: Dragula] #2674883
07/06/19 04:02 PM
07/06/19 04:02 PM
Iowa
Iowa
thank every body for there time to reply, helped a lot Dave
