Re: 9/16" tie rods, Fast ratio arms, etc...
[Re: AndyF]
#2664995
06/12/19 06:13 AM
06/12/19 06:13 AM
Posts: 636 Graz, Austria
DGS
Graz, Austria
Isn't the c-body pitman arm ball joint stud larger than on ABE cars so it doesn't interchange (I know the indexing is wrong too but that could be corrected with a file)?
ABE tie rods are 9/16" from factory - C-body is 11/16".
[Re: Kern Dog]
#2665044
06/12/19 09:10 AM
06/12/19 09:10 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Actually I believe the "normal" TR are 9/16" and the C body stuff might be 11/16".you saved. There is no engineering need for the 11/16" "upgrade" on a street driven car you mentioned, none, unless one has already added 3/8"+ thick LCA gussets with their KYB shocks. and running into curbs is one's idea of recreation. .
[Re: Sniper]
#2665410
06/13/19 07:28 AM
06/13/19 07:28 AM
Posts: 784 Florida
cbusters
Sure enough but if you have to buy a C-body pitman arm and the reamer (they are expensive) you could as well just get a fast ratio arm Wow, it has been a while since I bought a reamer, they are indeed expensive. If you know the angle you can buy one from Ebay. I saved a lot. Common use was for GM truck upgrade in the off-road field.
[Re: Kern Dog]
#2671084
06/28/19 11:30 AM
06/28/19 11:30 AM
jcc
Bitopia
How many miles have you put on the FF3 since new/install? I can't see it wore out yet anyway, something else must be at play, pun intended..
