horn stuck on #2664926
06/11/19 10:07 PM
06/11/19 10:07 PM
ontario canada kingston
aspenrt360 Offline OP
new one for me all these years never had it happen before! driving down the road in my wifes 72 dart and the horn starts blowing pull over pull horn button off of tuff wheel pull wire still blowing, go under hood pull horn wires to shut it up. have not had time yet to check it out, anyone else had this happen?going to try a spare relay if that does not do it it looks like time to trace wires.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: horn stuck on [Re: aspenrt360] #2665089
06/12/19 11:25 AM
06/12/19 11:25 AM
moparx Offline
moparx  Offline
over the years, i have had the horn wire on the turn signal switch break at the switch, then grounding on the internal column surface.
also, have had the spade plug in on the horn button come unplugged, causing the wire to ground on the wheel.
and, like you have said, the relay go bad.
i hope it's an easy fix for you.
please report back with what you find.
beer
Re: horn stuck on [Re: moparx] #2666698
06/16/19 10:50 PM
06/16/19 10:50 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Mine had a burr on the horn ground plate in the steering wheel that pierced the plastic insulator and grounded to the column.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: horn stuck on [Re: aspenrt360] #2666756
06/17/19 09:11 AM
06/17/19 09:11 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
begging disconecting the turning switch plug down the column. If stops, then the black wire on turning switch harness is being grounded somehow. Wire itself or as mentioned the pushrod got broken and is grounding with column surface around.
Or steering will contact is loosed and being grounded around
