Re: Issue Found. No compression rings?
[Re: dvw]
#2675503
07/08/19 12:16 PM
07/08/19 12:16 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The missing rings were on the work bench, but they were the ones my buddy gapped too big. He was supposed to grab new rings from another ring set, file-fit them and put them on the piston. I think Murphys Law and distractions, and having my friends 11-year old putting the ring compressor on the pistons all created the mess-up. But Saturday, pulled all the pistons, check all the rings, installed new rings on #3, and put it back together. Sunday (yesterday) got the engine back in the car and running (at 9:30 pm.) I'm sure the neighbors like hearing the engine fire up with no exhaust at that time of night.
[Re: 451Mopar]
#2675523
07/08/19 12:49 PM
07/08/19 12:49 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
There’s a lesson in there somewhere.
[Re: fast68plymouth]
#2675552
07/08/19 01:33 PM
07/08/19 01:33 PM
BradH
There’s a lesson in there somewhere. Ummmm... Don't have kids? Don't have friends? Don't post your embarrassing screw-ups on the 'net? I'm sure one or more of those might apply...
[Re: BradH]
#2675582
07/08/19 02:55 PM
07/08/19 02:55 PM
fast68plymouth
So. Burlington, Vt.
It’s probably something more like.......
Friends don’t let friends help put motors together.
[Re: BradH]
#2675910
07/09/19 10:10 AM
07/09/19 10:10 AM
451Mopar
Aurora, Colorado
There’s a lesson in there somewhere. Ummmm... Don't have kids? Don't have friends? Don't post your embarrassing screw-ups on the 'net? I'm sure one or more of those might apply... Do post your embarrassing screw-ups on the 'net, maybe there is something to learn from my mistakes Sort of like don't use a claw hammer to remove the harmonic balancer.... Or degree the cams ICL while measuring the exhaust lobe...
[Re: 451Mopar]
#2675929
07/09/19 11:06 AM
07/09/19 11:06 AM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
There’s a lesson in there somewhere. Ummmm... Don't have kids? Don't have friends? Don't post your embarrassing screw-ups on the 'net? I'm sure one or more of those might apply... Do post your embarrassing screw-ups on the 'net, maybe there is something to learn from my mistakes Sort of like don't use a claw hammer to remove the harmonic balancer.... Or degree the cams ICL while measuring the exhaust lobe... Or installing the trans, filling it with ATF & then realize the converter is in the trunk.
[Re: CSK]
#2675974
07/09/19 12:48 PM
07/09/19 12:48 PM
Posts: 43,367 Bend,OR USA
Cab_Burge
[quote=fast68plymouth]There’s a lesson in there somewhere. Ummmm... Don't have kids? Don't have friends? Don't post your embarrassing screw-ups on the 'net? I'm sure one or more of those might apply... :laugh2 Or installing the trans, filling it with ATF & then realize the converter is in the trunk. I'm glad I'm not thee only one who has had to learn some car lessons the hard way
