Re: 1978 w200 master cylinder
[Re: B1Frank]
#2664516
06/10/19 07:17 PM
06/10/19 07:17 PM
Posts: 20,660 in a cattle trailer down by th...
Guitar Jones
I can't give you a part number but my 93 RC has an aluminum master on it.
[Re: poorboy]
#2664714
06/11/19 10:53 AM
06/11/19 10:53 AM
Posts: 910 West Virginia
B1Frank
West Virginia
It has only two bolts....it has been a real job @#$%^&* ....to find the right one !!
[Re: Guitar Jones]
#2664720
06/11/19 11:09 AM
06/11/19 11:09 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
I can't give you a part number but my 93 RC has an aluminum master on it. My '82 did as well. RAYBESTOS MC39178 is listed to fit 1979 to 1993. Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2664770
06/11/19 01:47 PM
06/11/19 01:47 PM
Guitar Jones
I can't give you a part number but my 93 RC has an aluminum master on it. My '82 did as well. RAYBESTOS MC39178 is listed to fit 1979 to 1993. Robert You may have to change or adapt the fittings but it should bolt up to the booster. Just make sure the pushrod depth is the same.
