1978 w200 master cylinder #2664393
06/10/19 01:18 PM
06/10/19 01:18 PM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Hello,.to all,...i have a 78 dodge truck master cylinder with the small BRAKE BOOSTER,...im looking to drop the ### 12 pound master cylinder,...for a aluminum master cylinder,...i have seen other truck ,..but don't have any cross-over numbers to do this,....thanks for any info on this,...if anyone would know you guys are the best !....thanks Frank
Re: 1978 w200 master cylinder [Re: B1Frank] #2664516
06/10/19 07:17 PM
06/10/19 07:17 PM
Guitar Jones Offline
I can't give you a part number but my 93 RC has an aluminum master on it.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 1978 w200 master cylinder [Re: Guitar Jones] #2664546
06/10/19 09:34 PM
06/10/19 09:34 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Does your 78 master cylinder have 4 bolts or 2 bolts holding it onto the booster?
2 bolts are most Dodge trucks from about 80 up to the 94 model year.
4 bolts will probably requires a switch to something like an early 80s 5th Ave to get an aluminum master. Gene
Re: 1978 w200 master cylinder [Re: poorboy] #2664714
06/11/19 10:53 AM
06/11/19 10:53 AM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
It has only two bolts....it has been a real job @#$%^&* ....to find the right one !!
Re: 1978 w200 master cylinder [Re: Guitar Jones] #2664720
06/11/19 11:09 AM
06/11/19 11:09 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
My '82 did as well. RAYBESTOS MC39178 is listed to fit 1979 to 1993.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 1978 w200 master cylinder [Re: 3hundred] #2664770
06/11/19 01:47 PM
06/11/19 01:47 PM
Robert
You may have to change or adapt the fittings but it should bolt up to the booster. Just make sure the pushrod depth is the same.
Re: 1978 w200 master cylinder [Re: B1Frank] #2665159
06/12/19 02:20 PM
06/12/19 02:20 PM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
Go to Mancini racing, they have what your looking for and the adaptor to go to a 2 bolt master.
Re: 1978 w200 master cylinder [Re: 68dodge] #2665778
06/14/19 11:07 AM
06/14/19 11:07 AM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
My master cylinder is a two bolt,..i have a four bolt one with a big brake booster,....trying to stay with the small brake booster with a 440 under the hood,...
