W2 guide? #2664711
06/11/19 10:45 AM
06/11/19 10:45 AM
East Brunswick New Jersey
N
NoFrills Offline OP
NoFrills  Offline OP
N
Have a set of older w2s that I had a local shop working on. I have no history on the head. They are ported fairly good. Pressure test good. They started putting 11/32 gides in for me and got scared off. Looks to be a 1" od. guide started pushing out of the head. Have you ever seen any thing like this?
Re: W2 guide? [Re: NoFrills] #2664718
06/11/19 11:06 AM
06/11/19 11:06 AM
Washington
madscientist Offline
Washington
That's just the exhaust. If they are worried they can drive the guide in from the rocker side rather than the chamber side.
No big deal.
Re: W2 guide? [Re: madscientist] #2664863
06/11/19 07:25 PM
06/11/19 07:25 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
It seems I read something in a mopar tech book those guides seal to water. I would think your machine shop could bore your existing guide and repair it with out removing it.
Re: W2 guide? [Re: DavidDean] #2664868
06/11/19 07:38 PM
06/11/19 07:38 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’d just install 1/2” guides inside the existing guide.
Re: W2 guide? [Re: NoFrills] #2664920
06/11/19 09:53 PM
06/11/19 09:53 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I agree, just drill and ream them to .50 and install a bronze guide. Any good machine shop could do that for you.
Re: W2 guide? [Re: jwb123] #2664994
06/12/19 05:26 AM
06/12/19 05:26 AM
N
NoFrills Offline OP
NoFrills  Offline OP
N
