Re: MP/World block cross bolts, aren't bolts anymore [Re: 68roadrunner] #2664341
06/10/19 11:08 AM
06/10/19 11:08 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
This is just fyi. Allen's Fasteners in AZ sells individual ARP studs. They are listed by diameter and length. Very reasonably priced also.
Re: MP/World block cross bolts, aren't bolts anymore [Re: 68roadrunner] #2664345
06/10/19 11:17 AM
06/10/19 11:17 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Just replace the side bolts with an ARP bolt and all will be good - that side stud kit is worthless and will hit the headers
Re: MP/World block cross bolts, aren't bolts anymore [Re: sgcuda] #2664419
06/10/19 02:16 PM
06/10/19 02:16 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Are the cross studs coarse & fine threads like ARP studs? If so do you have enough course thread going into the main to cut off a 1/2 or 3/8" and still get full thread engagement? If so that's what I would do. Would give the same clearance as bolts.
Re: MP/World block cross bolts, aren't bolts anymore [Re: ZIPPY] #2664445
06/10/19 03:17 PM
06/10/19 03:17 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Originally Posted by ZIPPY
Originally Posted by Dragula
And the oil supply line itself.....You would be surprised, but everything wants to occupy that small space.
Yeah I can see how it could get cluttered right there. I'm going to run the oil line similar to the way your buddy's 572
was set up (the one with the 6 pack on it), so that might help a little.
Its tight on mine with one of the header tubes, and mine are bolts...
Re: MP/World block cross bolts, aren't bolts anymore [Re: Dragula] #2664466
06/10/19 04:39 PM
06/10/19 04:39 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
My Aluminum came with bolts but, I had lots of other fun...…
Re: MP/World block cross bolts, aren't bolts anymore [Re: fbs63] #2665174
06/12/19 02:38 PM
06/12/19 02:38 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Good find Bob, Thanks!...I have ordered individual ARP fasteners from McMaster-Carr as well but, they don't appear to have the selection that Allen's has.
Re: MP/World block cross bolts, aren't bolts anymore [Re: HardcoreB] #2665192
06/12/19 03:26 PM
06/12/19 03:26 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I noticed them online, but had no idea they were legit.
Thanks for the info...this won't be the last time I need to find those!
Rich H.
Esse Quam Videri
Re: MP/World block cross bolts, aren't bolts anymore [Re: ZIPPY] #2665412
06/13/19 07:42 AM
06/13/19 07:42 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
When the Indy block went out this winter for a tune up had the bolt hole counter sunk to get the clearance that was needed for that one bolt that always seems to be a pain.
1971 HEMI E BODY REGISTRY
