What goes here ? #2664163
06/09/19 09:06 PM
06/09/19 09:06 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
What goes between this emergency brake cable end and the pivot on the frame?
1980 w150
Re: What goes here ? [Re: lostdog] #2664179
06/09/19 10:05 PM
06/09/19 10:05 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Doesn't the cable end run towards the back? Somebody just looped that up to keep it from dragging. shruggy
Re: What goes here ? [Re: Dave Hall] #2664185
06/09/19 10:22 PM
06/09/19 10:22 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I put that steel rod in there to keep it from
Dragging. I need to know if I am missing something
Re: What goes here ? [Re: lostdog] #2664206
06/09/19 11:26 PM
06/09/19 11:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Where is the cable running from the rear backing plates forward.
Re: What goes here ? [Re: stumpy] #2664208
06/09/19 11:42 PM
06/09/19 11:42 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
There are attached to a cam rod attached to the pivot on the right circled in red.
Re: What goes here ? [Re: lostdog] #2664545
06/10/19 09:26 PM
06/10/19 09:26 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Your picture is pretty dark for my old eyes. It appears the pivot bracket is still present at your rear red circle. It also appears the front cable is slack and looped around to keep it off the ground.
Based on memory: Originally, the cable from the front attached to the bottom hole of the pivot bar. The two rear cables would attach to the 2 holes towards the top of the pivot arm. The pivot arm acted as a torque multiplier on the rear cables. Without it, you couldn't get enough movement through the cables to completely lock the rear brakes.There may have been a short bracket that the front cable stuck through and the nut threaded on to the threads on the end of the cable for adjustment. That bracket would have pinned through the lower hole in the pivot arm. Its been a long time, and the only picture I have here representing the cable attachment is really poor, and I have no way of reproducing it onto the computer. In a service manual it should be located in the brake section, rear cable routing. Gene
Re: What goes here ? [Re: poorboy] #2668805
06/22/19 07:53 PM
06/22/19 07:53 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I don't have my truck here to take a picture but I found this one on Ramchargercentral. Basically from what I remember the cable from the pedal goes the bottom of the arm on the frame with that threaded adjuster to get the tension right. Then there's another piece you're missing that attaches to the arm and pulls on each cable going to the brakes.
Re: What goes here ? [Re: 440newport] #2669314
06/24/19 11:07 AM
06/24/19 11:07 AM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
Yep you are missing a few parts - see attached picture this should help you
David S.
Part Time Owner
Dodge Connection
www.dodgeconnection.com
904-209-9388
