horn relays ?
#2664046
06/09/19 02:26 PM
06/09/19 02:26 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I have a 4 pin relay on my 73 Duster, is the separate pin for the door buzzer ? TIA Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: horn relays ?
[Re: deaks]
#2664048
06/09/19 02:33 PM
06/09/19 02:33 PM
Posts: 6,358 nowhere
Sniper
nowhere
Looks like that fourth wire, black, goes to the left door switch A link to the wiring diagrams in case you don;t have it. I used 73 Valiant since the Duster is based off the Valiant.
Re: horn relays ?
[Re: deaks]
#2664073
06/09/19 04:34 PM
06/09/19 04:34 PM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
all 71/73 Mopars got the 4th prong for the KEY IN buzzer as standard equipment integrated on horn relay. Not a door buzzer, but only buzz when key is in and DRIVER'S door is opened. Since 74 was a separated buzzer controled by the interlock brain box
Re: horn relays ?
[Re: NachoRT74]
#2664113
06/09/19 06:31 PM
06/09/19 06:31 PM
deaks
robin hood country
The wiring diagram shows a single black wire on the single pin but mine has a double blue wire on it and my meter shows continuity with one end on there and the other on the horn wire but when I connect it to the relay the horn is making a closed circuit without pressing the button. Mick
Re: horn relays ?
[Re: deaks]
#2664239
06/10/19 04:03 AM
06/10/19 04:03 AM
deaks
robin hood country
Been looking through the diagrams on my mopar and the 76 shows blue wire coming off the single pin, my 73 has two blue into one connector.
Re: horn relays ?
[Re: deaks]
#2664330
06/10/19 10:43 AM
06/10/19 10:43 AM
NachoRT74
Valencia, España
have no idea what you talk about.
Blue wires are on 73s ( practically on all cars ) for RUN circuit which, inside the cab, feeds the seatbelt warning system too ( buzzer and lights ) since turns on when you put the key in RUN. Sooo you must be looking at something else.
Driver side door jam switch must get a yellow wire for dome light and black wire for warning buzzer systems. Passenger side just yellow.
I can be missing something because I'm thinking based on what I recall and my B body gets. However I don't think A body or any other body is way diff and my memory uses to be good
Re: horn relays ?
[Re: NachoRT74]
#2664372
06/10/19 12:28 PM
06/10/19 12:28 PM
deaks
robin hood country
If you look at the 73 diagram i've attached, there's a black wire on the fourth pin, mine has 2 blues into one connector. Mike
Re: horn relays ?
[Re: deaks]
#2664477
06/10/19 05:36 PM
06/10/19 05:36 PM
deaks
robin hood country
Could I utilise one of the 3 pin relays I already have, if I split the wires ?
Re: horn relays ?
[Re: deaks]
#2664687
06/11/19 09:17 AM
06/11/19 09:17 AM
NachoRT74
Valencia, España
well... must be a single black wire. My uncle's 73 Dart got a single black wire there. Blue wire could be for some accesorie around, in your case, maybe seatbelt buzzer system. Search for a black wire with female terminal hanging around without use and plug it there. The black wire arriving must be just the ground coming from ign key sensor, which on column is one of the reds for this switch. The other red comes from door jam switch ground ( also black on underdash harness )
Re: horn relays ?
[Re: NachoRT74]
#2664845
06/11/19 06:11 PM
06/11/19 06:11 PM
deaks
robin hood country
I hear you but my multimeter, sounded the horn wire to the blue connecter. The old relay was faulty, so I tried a 3 pin relay I had and it's buzzing continously, even with the horn wire not grounded.
Re: horn relays ?
[Re: deaks]
#2664989
06/12/19 03:24 AM
06/12/19 03:24 AM
NachoRT74
Valencia, España
Well, that wrong! The 4th pin must not affect the horn function since is just dedicated to the key in buzzer when driver side door gets opened.
Runs like this: Violet... batt power from fuse box Green traced red... horn signal ( positive ) when horn is triggered at steering wheel Black grouped on the 3 group prongs... ground signal from horn switch. It comes from turning switch plug Black separated prong... ground signal from key in switch sensor, which cames at the same time from door jam switch. When both switches are closed ( open driver's door and key inserted ) the buzzer gets the ground circuit for it closed and buzzes.
That is what must be. Nothing else.
Re: horn relays ?
[Re: Sniper]
#2665075
06/12/19 10:54 AM
06/12/19 10:54 AM
NachoRT74
Valencia, España
Can't tell whatever diagrams and FSM says, but what really makes it work.
on a side, I never trust completelly on diagrams posted at MyMopars.com. They work as a guide but they are not perfect. They forgot about interlock system on all 74 models and never say anything about accesories
THIS is the setup on 71/73 Mopars ( I made the diagram quite ago )
Re: horn relays ?
[Re: NachoRT74]
#2665593
06/13/19 06:27 PM
06/13/19 06:27 PM
deaks
robin hood country
Thanks for your replies, when I connect the violet and the green tracer to the relay it continually buzzes, even without the horn button wire ?
