Re: Hemi valve cover breathers
[Re: Cape]
#2664297
06/10/19 09:39 AM
06/10/19 09:39 AM
Posts: 4,213 New York
polyspheric
New York
"Breather": eye candy that sprays blow-by fumes all over the engine compartment.
Is this a street car?
Boffin Emeritus
[Re: Cape]
#2664412
06/10/19 02:06 PM
06/10/19 02:06 PM
Posts: 43,309 Bend,OR USA
Cab_Burge
Are you saying you bought the stock style stamp steel covers or the cast aluminum covers? Do you want push on breather caps or the other bolt on type?
[Re: Cape]
#2664515
06/10/19 07:09 PM
06/10/19 07:09 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
I'm running these C-7197 blow-down breathers from Good Vibrations Motorsports. See: https://goodvibesracing.com/Burndown_Tubes.htm#1.25They are taller than I expected. I connected some high-temp reinforced clear tubing with Oetiker Clamps to the outlets and ran both tubes to a Moroso air/oil separator. Works for me ....
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
