wheel rim screws holes too loose! #2663164
06/06/19 06:06 PM
06/06/19 06:06 PM
Penna
70satelliteguy Offline OP
Penna
Just putting my new slicks on and several of the holes are too loose to reinstall the rim screws. I am using the summit kit which has .250 diameter /.75 long screws. I tried wrapping them with tape but they still won't bite.
Can I just install a next size screw in there? What to do??
Thanks mIke
Re: wheel rim screws holes too loose! [Re: 70satelliteguy] #2663167
06/06/19 06:12 PM
06/06/19 06:12 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I haven't screwed my slicks in years but I think Morosso or someone offered screws that were slightly over-sized for this.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: wheel rim screws holes too loose! [Re: 70satelliteguy] #2663170
06/06/19 06:22 PM
06/06/19 06:22 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
Use more pressure when attempting to install the screws. They should screw into the tire, not the wheel. Screws that are threaded into the wheel tend to push the beads away from the wheel. My tires are screwed and tubeless.
Re: wheel rim screws holes too loose! [Re: cagebob1] #2663186
06/06/19 06:40 PM
06/06/19 06:40 PM
Penna
Penna
Tried putting more pressure to install but does not seem to be working! Wondering what the next size screw is?
Any other ideas?
Mike
Re: wheel rim screws holes too loose! [Re: 70satelliteguy] #2663190
06/06/19 06:52 PM
06/06/19 06:52 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Any other ideas?
Mike
Through the screws away and use Permatex High Tack™Gasket Sealant Item # 80063
Been 1.240 60ft with tubes with this method. Tires haven't moved an inch in 91 passes
Doug
Re: wheel rim screws holes too loose! [Re: 70satelliteguy] #2663192
06/06/19 06:59 PM
06/06/19 06:59 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I run a 1/8" drill into the tire to make a pilot hole. Put a piece of steel tubing over the drill bit to stop the drill from going through the tire. Drill between the 2 steel bands running through the tire bead. The screw will then grab in between the bands and hold the tire to the rim.
Re: wheel rim screws holes too loose! [Re: sgcuda] #2663205
06/06/19 07:33 PM
06/06/19 07:33 PM
Penna
Penna
Didn't know there were steel bands in slicks?
How far to drill into the bead?
Thanks Mike
Re: wheel rim screws holes too loose! [Re: dvw] #2663208
06/06/19 07:36 PM
06/06/19 07:36 PM
Penna
Penna
"Through the screws away and use Permatex High Tack™Gasket Sealant Item # 80063
Doug
That is an idea!
Mike
Re: wheel rim screws holes too loose! [Re: 70satelliteguy] #2663226
06/06/19 08:08 PM
06/06/19 08:08 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
If looks is not important then just move over and drill a new hole beside the ones that are bad, but if looks are important then disregard
Re: wheel rim screws holes too loose! [Re: dartman366] #2663231
06/06/19 08:18 PM
06/06/19 08:18 PM
Penna
Penna
Dartman that is what I was thinking also! That or finding 1/4 inch/3/4 screws that would go into the bad holes and rethread the holes for a tight fit. Do you think either one will it will affect the tire balance?
Thanks Mike
Re: wheel rim screws holes too loose! [Re: 70satelliteguy] #2663244
06/06/19 08:43 PM
06/06/19 08:43 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
as mentioned before the Moroso screws seem to be a little meatier than a standard screw of the same claimed size,I know when I changed screws after several slick changes the holes were getting sloppy but not stripped out, bought the Moroso's and all was tight again,, one other thing you might look into would be try to find a metric screw that is slightly larger in diameter than the 1/4 screw,, as far as balance, I personally think it would be neglegable but if you know someone that has a bubble balancer you could check it before and after if for nothing more than piece of mind.
Re: wheel rim screws holes too loose! [Re: 70satelliteguy] #2663256
06/06/19 08:59 PM
06/06/19 08:59 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I only use good screws. Moroso, Jegs gr 8.The real trick I've found is cut some aluminium rivet nails 1/4"-3/16 long. Lay them in the hole and put the screws in with a light rechargeable impact . Dont over tighten them. This has worked well for me.
Re: wheel rim screws holes too loose! [Re: DavidDean] #2663274
06/06/19 09:40 PM
06/06/19 09:40 PM
Penna
Penna
"The real trick I've found is cut some aluminium rivet nails 1/4"-3/16 long. Lay them in the hole and put the screws in with a light rechargeable impact . Dont over tighten them. This has worked well for me.
Will look into this also tomorrow when I go to the hardware store.
Thanks Daviddean !!
Mike
Re: wheel rim screws holes too loose! [Re: 70satelliteguy] #2663298
06/06/19 11:10 PM
06/06/19 11:10 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
4 things
Use good screws. I only use the Morosos.
Replace the screws. Screwing into the bead dulls the point on the screws. Two uses and they are done.
Drill a small starter hole in the tire. 1/16, 3/32 maybe.
Lube the screw (JB80) and apply pressure while screwing them in.
Re: wheel rim screws holes too loose! [Re: CMcAllister] #2663304
06/06/19 11:41 PM
06/06/19 11:41 PM
PA.
"Little"John
"Little"John
PA.
5. Pump the slicks up to 18-20 pounds to push the beer against the wheel
6. Use so type of mechanical stop on the drill bit so you don’t drill through the slick. I always just wrapped black electrical tape around the drill bit for a stop and saved it for that specific job.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: wheel rim screws holes too loose! [Re: CMcAllister] #2663363
06/07/19 08:07 AM
06/07/19 08:07 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Originally Posted by CMcAllister
4 things
this is how ive always done it,never a prob.
Re: wheel rim screws holes too loose! [Re: bonefish] #2663385
06/07/19 09:31 AM
06/07/19 09:31 AM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
When you have a worn hole screwing slicks on I take a waste piece of aluminum from a aluminum pop rivet (the part that goes in the rivet gun) and cut it about 1/4" long, slip it in the hole and the screw will get traction again. Has saved me many times, much like using a toothpick in a wooden hole. Using an impact or pressure will just strip the aluminum out worse, take your time and use new screws if the one you have our dull, never have had to drill the tire???
Re: wheel rim screws holes too loose! [Re: Keith Richards] #2663443
06/07/19 11:32 AM
06/07/19 11:32 AM
Penna
Penna
Update!!!
I just returned from the hardware with some .25 pop rivets and some new metric screws. The screws that came with the kit measure .237 (after many uses) and the new screws measure .247. The new ones went right in and solved the problem. Anyone need some extra pop riverts?
Off to the races tonight!!
Thanks for all the reply's.
Mike
Re: wheel rim screws holes too loose! [Re: 70satelliteguy] #2663505
06/07/19 01:40 PM
06/07/19 01:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
A plastic zip tie will tighten it right up. Slide the zip tie in the hole with the screw and use an electric impact or drill and they will go in just fine.
Re: wheel rim screws holes too loose! [Re: Al_Alguire] #2663531
06/07/19 03:13 PM
06/07/19 03:13 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
changed slicks several times, holes got worn out , get a flat pin punch bigger then hole, tap hole flat it will tighten up
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
