Re: wheel rim screws holes too loose!
[Re: 70satelliteguy]
#2663167
06/06/19 06:12 PM
06/06/19 06:12 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I haven't screwed my slicks in years but I think Morosso or someone offered screws that were slightly over-sized for this.
#2663190
06/06/19 06:52 PM
06/06/19 06:52 PM
Posts: 9,865 MI, usa
dvw
MI, usa
Tried putting more pressure to install but does not seem to be working! Wondering what the next size screw is? Any other ideas? Mike Through the screws away and use Permatex High Tack™Gasket Sealant Item # 80063 Been 1.240 60ft with tubes with this method. Tires haven't moved an inch in 91 passes Doug
#2663226
06/06/19 08:08 PM
06/06/19 08:08 PM
dartman366
Mt. Vernon, Ohio
If looks is not important then just move over and drill a new hole beside the ones that are bad, but if looks are important then disregard
#2663244
06/06/19 08:43 PM
06/06/19 08:43 PM
dartman366
Mt. Vernon, Ohio
as mentioned before the Moroso screws seem to be a little meatier than a standard screw of the same claimed size,I know when I changed screws after several slick changes the holes were getting sloppy but not stripped out, bought the Moroso's and all was tight again,, one other thing you might look into would be try to find a metric screw that is slightly larger in diameter than the 1/4 screw,, as far as balance, I personally think it would be neglegable but if you know someone that has a bubble balancer you could check it before and after if for nothing more than piece of mind.
#2663298
06/06/19 11:10 PM
06/06/19 11:10 PM
Posts: 11,645 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
4 things
Use good screws. I only use the Morosos.
Replace the screws. Screwing into the bead dulls the point on the screws. Two uses and they are done.
Drill a small starter hole in the tire. 1/16, 3/32 maybe.
Lube the screw (JB80) and apply pressure while screwing them in.
[Re: CMcAllister]
#2663304
06/06/19 11:41 PM
06/06/19 11:41 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
5. Pump the slicks up to 18-20 pounds to push the beer against the wheel
6. Use so type of mechanical stop on the drill bit so you don’t drill through the slick. I always just wrapped black electrical tape around the drill bit for a stop and saved it for that specific job.
[Re: CMcAllister]
#2663363
06/07/19 08:07 AM
06/07/19 08:07 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
4 things
Lube the screw (JB80) and apply pressure while screwing them in. this is how ive always done it,never a prob.
[Re: bonefish]
#2663385
06/07/19 09:31 AM
06/07/19 09:31 AM
Posts: 2,946 Windsor ,Ca.
Keith Richards
Windsor ,Ca.
When you have a worn hole screwing slicks on I take a waste piece of aluminum from a aluminum pop rivet (the part that goes in the rivet gun) and cut it about 1/4" long, slip it in the hole and the screw will get traction again. Has saved me many times, much like using a toothpick in a wooden hole. Using an impact or pressure will just strip the aluminum out worse, take your time and use new screws if the one you have our dull, never have had to drill the tire???
#2663505
06/07/19 01:40 PM
06/07/19 01:40 PM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
A plastic zip tie will tighten it right up. Slide the zip tie in the hole with the screw and use an electric impact or drill and they will go in just fine.
[Re: Al_Alguire]
#2663531
06/07/19 03:13 PM
06/07/19 03:13 PM
Posts: 1,610 westerly, ri. usa
440lebaron
westerly, ri. usa
changed slicks several times, holes got worn out , get a flat pin punch bigger then hole, tap hole flat it will tighten up
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
