Cleaning White Letter Tires #2663087
06/06/19 01:52 PM
06/06/19 01:52 PM
London, England
JFChallenger440 Offline OP
London, England
Buying a 2nd hand set of wheels at the weekend with RWL tires that are really dirty and grubby, what's the best way of getting the "whiteness" back to the letters ? Or is it a case of buying one of those white letter pens ? Thanks
Re: Cleaning White Letter Tires [Re: JFChallenger440] #2663090
06/06/19 01:59 PM
06/06/19 01:59 PM
WI
Dcuda69 Online content
Dcuda69  Online Content
WI
My truck has RWL tires. I use a small piece of scotch brite. Makes them nice and white. BTW those RWLs will be gone as soon as they're worn out.....absolutely hate trying to keep them clean.
Re: Cleaning White Letter Tires [Re: Dcuda69] #2663095
06/06/19 02:09 PM
06/06/19 02:09 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Acetone on a rag.
Scotchbrite pad and soap, Ajax etc
Re: Cleaning White Letter Tires [Re: JFChallenger440] #2663098
06/06/19 02:22 PM
06/06/19 02:22 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Wesleys Bleachwhite!
Re: Cleaning White Letter Tires [Re: Jwilli500] #2663100
06/06/19 02:31 PM
06/06/19 02:31 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
All of the above, and SOS/Brillo pads
Re: Cleaning White Letter Tires [Re: 318 Stroker] #2663117
06/06/19 03:48 PM
06/06/19 03:48 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I used to use SOS pads back when I used to have tires with with stuff on them.
Re: Cleaning White Letter Tires [Re: Jwilli500] #2663119
06/06/19 03:50 PM
06/06/19 03:50 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
This! But be careful to not get it on aluminum rims it will dull polished aluminum.
Re: Cleaning White Letter Tires [Re: challenger70] #2663124
06/06/19 04:08 PM
06/06/19 04:08 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I'll use Wesleys on a rag.
I discovered long ago that it can ruin argent wheel paint & center cap finishes, so avoid spraying.
Re: Cleaning White Letter Tires [Re: JFChallenger440] #2663141
06/06/19 05:17 PM
06/06/19 05:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Best thing for RWL's is a can of black spray paint. primer
Re: Cleaning White Letter Tires [Re: John_Kunkel] #2663160
06/06/19 05:59 PM
06/06/19 05:59 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
A little bit of Comet or similar cleanser on wet rag . . .
Re: Cleaning White Letter Tires [Re: a12rag] #2663184
06/06/19 06:39 PM
06/06/19 06:39 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
If those tires are BF Goodrich they will have brown letters forever.
Re: Cleaning White Letter Tires [Re: a12rag] #2663267
06/06/19 09:21 PM
06/06/19 09:21 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Purple cleaner let it set for short time a stiff brush and white again. primer
Re: Cleaning White Letter Tires [Re: Jwilli500] #2663349
06/07/19 04:50 AM
06/07/19 04:50 AM
crlush Offline
crlush  Offline
iagree
Re: Cleaning White Letter Tires [Re: challenger70] #2663375
06/07/19 09:06 AM
06/07/19 09:06 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
True!
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Cleaning White Letter Tires [Re: 469runner] #2663427
06/07/19 11:02 AM
06/07/19 11:02 AM
Hinckley, Ohio
KWF340 Offline
KWF340  Offline
Hinckley, Ohio
Yup. Certain BFGs have a problem where the lettering turns brown and stays that way no matter what you do (other than paint over them). I have this problem on my rear tires, while the fronts do not (smaller front tires). All four purchased at the same time from the same location. I read BFG will replace them under warranty if they are from the batch that has issues. I've been meaning to contact them but its never been a priority. Something to add to my list of things to do.
1968 Charger R/T, 440 Auto, GG1;
1969 Super Bee, 383, 4-speed, T5;
1969.5 Road Runner, 440-6, 4-speed, 96;
1970 Duster 340, 4-speed, EV2;
1970 Charger R/T SE, 440 (496), Auto, EB3;
1970 Dart Swinger 340 (416), 4-speed, EV2;
1970 Corvette coupe, LS5, 4-speed, Daytona yellow;
2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
Re: Cleaning White Letter Tires [Re: 469runner] #2663496
06/07/19 01:27 PM
06/07/19 01:27 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I whiten all my WLT's regardless of the brand, including BFG's, (even my Polyglas GT repros brown out) easily with trichlorethlene (TCE)
Re: Cleaning White Letter Tires [Re: KWF340] #2663612
06/07/19 08:04 PM
06/07/19 08:04 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Replaced BFG RWL’s on my 71 Vette 2 times under warranty. Since Michelin took over the company, larger sized RWL tires will be RBL letters. They have added silicone to their rubber recipe. I have no idea why the smaller sizes are still ok,,,,have not checked lately. 275-60-15 on rear 255-60-15 on front.
In disgust I reversed to put black walls out. Actually have gotten used to them this way, and now prefer.
However blackwalls also brown,,,,just does not show so obvious. Decent tire detailer products will make them presentable for a while. Michelin should be ashamed for ruining this iconic tire.
Coker is a big seller of them. Perhaps they can offer current information. I went thru all the tire exchanges 3 years ago.
Friend of mine bought 4 tires for his Roadrunner. Rear 275-60-15,,,front 235-60-15. Rear RWL are completely brown,,,Fronts are ok RWL. Looks as though he never details his rears.
Re: Cleaning White Letter Tires [Re: Sxrxrnr] #2663739
06/08/19 09:36 AM
06/08/19 09:36 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
I use lacquer thinner on a rag to wipe ONLY the raised white letters. Then wipe the tires with 3M Leather & Vinyl cleaner on a sponge applicator. Leaves a low gloss sheen after applied and bright white letters.
Ron
Re: Cleaning White Letter Tires [Re: Ronnman] #2663837
06/08/19 07:14 PM
06/08/19 07:14 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Would not help raised brown letters. Tried this 3 years ago. Even tried grinding with a Dremel sander did nothing except grind the letters down. This brown bleeds up from the tire carcass, thru the letters and when hitting the outside atmospheric, turns brown like a day old avocado or a peeled apple.
The blue or green protective coating on brand new rwl’s, protects them until this coating is scrubbed off.
As the adage goes: “beauty is only skin deep, ugly goes clear to the bone”.
Using the complete chemistry lab of detailing and cleaning products in my garage,,,it is substantial,,,nothing works on these tires. If something works, you do not own these tires. You have tires manufactured before Michelin got their hamfisted paws on these tires.
From 3 years ago posting on topic
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/2161193/Searchpage/1/Main/172528/Words/%2BGoodrich+%2Braised+%2Bwhite+%2Bletter+%2Btires/Search/true/re-bfg-ta.html#Post2161193
Re: Cleaning White Letter Tires [Re: JFChallenger440] #2663861
06/08/19 09:59 PM
06/08/19 09:59 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Soft scrub cleanser and a light duty scouring pad. One om motorcycle customers always had super clean whitewalls on his bike,this was his secret.I use it to clean WW on new tires now.
RT
